A good car aerial to buy?
Submitted: Sunday, Apr 13, 2008 at 22:15
ThreadID: 56610 Views:4465 Replies:6 FollowUps:4
Howdy folks, hows things?
Yep, I snapped my radio aerial off my Cruiser the other day & im looking for a new one.
Any tips on a cost effective, strong (unbreakable?) & good reception/ pickup aerial at all?
Cheers in advance
Ro
Reply By: Kev. (Cairns) - Sunday, Apr 13, 2008 at 22:26
Ive always installed the cheap rubber flexible ones from the local auto store, never had a problem.
AnswerID: 298369
Follow Up By: Nick R (VIC) - Sunday, Apr 13, 2008 at 22:33
same here, unbreakable....
and at $14.95 you can't go wrong
Carpe Cerevisi
FollowupID: 564473
Follow Up By: Richard W (NSW) - Monday, Apr 14, 2008 at 18:31
Rowen,
Another one for the short flexible ones although I don't think the reception is as good in fringe areas.
FollowupID: 564588
Reply By: Member - Oldplodder (QLD) - Monday, Apr 14, 2008 at 07:49
I have a stainless steel whip aerial.
Same as the uhf/27meg radio ones, but a bit longer for the AM/FM band.
Can bend it back 180 degrees.
Have the same problem with the pajero, the aerial is mounted on the passenger side, and it got wiped out twice on low hanging branches, even when down half way. Last time it was not recoverable, and a new one was over $100.00.
So bought the laser whip aerial, about the same price as the a uhf aerial. We prefer listening to local radio when travelling and we can pick up AM for about 300 to 400k. Had it for over 10 years now.
AnswerID: 298399
Follow Up By: Stu & "Bob" - Monday, Apr 14, 2008 at 15:14
John,
Where do you get them from?
Stu
FollowupID: 564535
Follow Up By: Member - Oldplodder (QLD) - Monday, Apr 14, 2008 at 16:01
I went to my local uhf radio place.
It was Northfield here in Brisbane, and asked for a whip aerial for the AM/FM radio that wouldn't easily break and give good reception.
The laser whip is what they recommended.
FollowupID: 564542
Reply By: Mr Pointyhead - Monday, Apr 14, 2008 at 08:10
I installed a aftermarket electric aerial from supercheap. It means I can easily retract the aerial when in the bush, and when I forget to do that it is easy to replace the mast.
I have a 100 series and it was easy to install. However, if you have a 80 series it is a lot more difficult to get access to the aerial as you need to remove the inner guard.
AnswerID: 298402
Reply By: Member -Signman - Monday, Apr 14, 2008 at 09:47
the good ole wire coat hanger always works....
AnswerID: 298410
Reply By: KSV. - Monday, Apr 14, 2008 at 12:06
If you are after FM, then to have really good reception outside metro area you need as long as possible antenna mounted on the roof. In metro area anything will do. AM less sensitive to antenna setup – to have real advantage from antenna for AM reception you have to hung long (50m or more) piece of wire on tree :-)))). But if you were happy with standard antenna, then anything will do. As some suggest even wire coat hunger, thou ugly. Unless you after good reception for FM I suggest as other says – go with rubber, unbreakable and cheaper then cheeps.
Serg
AnswerID: 298426
Reply By: Member - Davoe (Yalgoo) - Monday, Apr 14, 2008 at 15:43
good luck getting the old one out. i ended up tearing mine out and the replacement needed a big enough base to cover the incident
AnswerID: 298443
