carby rb30?!
Submitted: Monday, Apr 14, 2008 at 12:03
ThreadID: 56616 Views:2936 Replies:6 FollowUps:0
hi all,
I have a GQ 3L carbied jobby... I heard on the grapevine that under the carby is some honeycomb restrictor thingy and if it was removed i would get more power and economy can anyone help me with this?
Reply By: pcpitstop - Monday, Apr 14, 2008 at 12:16
Hey mate, its there for a reason, to protect your engine, if you remove it you will prob allow more air flow, therefore increasing power. But its up to yourself if you want to risk that. Its your call
AnswerID: 298427
Reply By: Robin Miller - Monday, Apr 14, 2008 at 12:47
That restrictor does limit air flow a bit Tag's.
But the car is hard to start and runs rough when cool without it.
Leaving it on and re-curving the distributor and some jetting changes were all that was required to get mine to 145kw however this power was useless for 4wding and I chucked that stuff away and converted to fuel injection instead which only gave about 115kw but made it a better 4wd.
AnswerID: 298428
Reply By: Tags' GQ - Monday, Apr 14, 2008 at 13:10
thanks guys will keep that in mind
AnswerID: 298431
Reply By: Jim from Best Off Road - Monday, Apr 14, 2008 at 13:35
Russel Guest 4wd, Melbourne used to do something for about $400 that apparently gave them a lot more hoot.
AnswerID: 298438
Reply By: Tags' GQ - Monday, Apr 14, 2008 at 16:35
what do you mean by re-curving the dizzy rob?
AnswerID: 298450
Reply By: nowimnumberone - Monday, Apr 14, 2008 at 18:04
under the carby on the rb30 is a plate that looks like half a bit of pipe that drops down into the manifold they are very thin and brake of getting stuck in valves etc
it happened to me and 2 others i know of not from a blokes mates girlfriends exs brother in law
removal causes no issues
AnswerID: 298469
