03 GU problem...need advise please
Submitted: Monday, Apr 14, 2008 at 20:15
Member - John M (QLD)
Hi all, on an recent outing to a 4wd
park i have discovered a problem,as i was just starting my accent, in 4wd low and in first gear and feeding the throttle it would rev to about 1100 rpm then die......even with a run-up again in the same gear same result tried 3 times finally got up the
hill although nearly valve bouncing , however without that run up i would have not made it this is not normal any advies would greatly be apreciated. Its a 2003 GU 3lt diesel any suggestions??????? going to cape later in year and need to sort problem
Reply By: Member - Mick O (VIC) - Monday, Apr 14, 2008 at 20:20
John,
slip a question into the
Patrol Forum. Someone will know what's going on.
Cheers. Mick
298523
Reply By: Member - David P (VIC) - Monday, Apr 14, 2008 at 20:55
you got lots of revs but no power, is that right??
298536
Follow Up By: Member - John M (QLD) - Monday, Apr 14, 2008 at 21:05
yes david thats right but as soon as i start climbing it loses power either i have to rev f### out of it or back down to a flat surface and start again
564661
Follow Up By: Member - David P (VIC) - Monday, Apr 14, 2008 at 21:14
just a thought , brake light adjustment?? In my auto I use left foot for braking and found if I still had the brake lights on when merging the fuel was cut to idle (embarrassing). Thinking if its a bit rough and the brake lights are set a bit hair trigger it may be cutting fuel, just a thought...silverback
564666
Follow Up By: Member - John M (QLD) - Monday, Apr 14, 2008 at 21:19
thanks for that david but i have just had the pedal position sensor replaced so fuel is not the problem maybe internal,,possibly too much lag on thr turbo, going to nissan on wednesday thanks for your advise......john
564668
Follow Up By: the nugget - Thursday, Apr 17, 2008 at 11:02
Hi John M,
Did you find out what the problem was with your Patrol. I am experiencing something similar,
mine is due for a major service soon and is still under extended warranty.
The Nugget
565172
Reply By: Member - Andrew (WA) - Monday, Apr 14, 2008 at 21:31
Your issue will be the air flow sensor, I'll put a $1 on it. Have you got an original air filter or after market job? Anything other than original Nissan air cleaners in these is a BIG no no.
Even if you haven't, your issue sounds very familiar to others I have seen.
If you have no luck trying other suggestions...go straight into Nissan and get a new a AFS, ASAP!
Good luck.
298553
Follow Up By: nowimnumberone - Tuesday, Apr 15, 2008 at 18:32
we have fitted 100s and 100s of non genuine air filters to 3ltr partols never seen a air flow sensor stuff up because of type of air filter
infact last air flow meter we replaced actually had nissan filter.
where did you hear this rubish
564832
Follow Up By: Member - Glenn D (NSW) - Tuesday, Apr 15, 2008 at 20:40
#1
I think Andrew means after market oiled foam type filters, apparently the oil contaminates the MAS.
Glenn.
564875
Follow Up By: Member - John M (QLD) - Tuesday, Apr 15, 2008 at 20:44
hi andrew, pitty you didn't put more money on bet, all air flow components and the air were serviced and replaced last week including the filter (original nissan one) thank you for taking the time to respond with your advice....regards john
564877
Follow Up By: Member - Andrew (WA) - Tuesday, Apr 15, 2008 at 21:04
nowimnumberone
Mate, I thought it was common knowledge but obviously not. And like you say, it even happens with the original air filters but filters that require oiling really stuff up the MAFS. (in my experience)
If you haven't experienced this type of thing, no worries.
I have however, seen it many times and it happened to me.
I was merely stating my suggestion based on experience to help the guy resolve the issue asking the question. Be it right or wrong.
I'm just glad I only lost $1
564883
Follow Up By: Muzzgit [WA] - Wednesday, Apr 16, 2008 at 00:40
While on the subject of non genuine filters, if you go to repco or anywhere like that and ask for an airfilter for a 3.0 patrol you will not be given the right one!
The filter you will be given is simply a dry paper element filter (
grey in colour) and the correct one for the 3.0 patrol is a cilicon coated paper element (red in colour).
I have had several disputes with mechanics about it because of problems I had while in the
Kimberley in 2003 and the car had been fitted with the wrong filter. The MAFS was compromised by dust getting past the filter.
564934
Follow Up By: Leroy - Thursday, Apr 17, 2008 at 12:25
Muzz,
You are very correct! The dry paper elements still let through particles that sand balst the MAF.
Leroy
565177
Reply By: Stephen M (NSW) - Monday, Apr 14, 2008 at 21:50
John, there was question on here the other day/week about a similiar thing. Im not sure wether it was related to the 3 litre or the 4.2 or might even be a later model patrol but was some thing to do with the accelerator pedal and some switch on it. Cost them $799 to fix as you had to buy the complete accelerator pedal assembly. I might be totally incorrect and sure some one will say if I am. I will do a search and see if I can find it. Regards Steve M
298560
Follow Up By: Stephen M (NSW) - Monday, Apr 14, 2008 at 22:00
Found it thread no 56483. "Here was the question"
Hi all i am a new member so bare with me ...no profile yet.
Here is some advise to all out there that own a 2003 GU Patrol....... I have owned
mine for only 3 months bought it with 60,000kms on the clock, i had a problem with quick acceleration the patrol would not respond and die down to idle revs, didnt matter what gear or at what speed if i hit the throttle quick it would not respond without completely getting off the accelerator and the of course changing down a gear or two,,,,very dangerous in some situations, like roundabouts for example, so for you people out there that could be having the same problem, it is the " pedal position sensor" which requires a completely new pedal kit with a small cost of $700.00. Hope this might help someone out there
564680
Follow Up By: Stephen M (NSW) - Monday, Apr 14, 2008 at 22:02
Not the same thing, but maybe related ??? Regards Seve M
564682
Follow Up By: Member - John M (QLD) - Tuesday, Apr 15, 2008 at 20:30
hi steve thanks for the advise, but i posted that thread last week since that it has been fixed and powering fine.... thanks
john
564870
Follow Up By: Stephen M (NSW) - Tuesday, Apr 15, 2008 at 20:43
Sorry
John, didn't even look at who posted it, Di@khead me. Glad you fixed it anyway, nothing worse then an intermittent fault. Regards Steve M
564876
Reply By: Member - Roachie (SA) - Tuesday, Apr 15, 2008 at 20:39
What about the fuel filter? Have you changed it recently? If not, then maybe a good idea to do so. If yes, then
check that it is tightly done up. If there is ANY chance of air getting sucked in, then it will.
Also, did you have plenty of fuel in the tank? If it was under a quarter of a tank, then it is possible that you were not getting enough fuel once you started the ascent as the fuel surged away from the pick-up point in the tank.
I'm a great believer in having a secondary electric (Facet) fuel pump fitted to ensure you get a positive fuel delivery (of course this won't fix up the issue of low fuel level in the tank).
Good luck, Roachie
298750
Reply By: Member - John M (QLD) - Wednesday, Apr 16, 2008 at 18:45
thank you ever so much for your replies and advice but i regards to the problem, after spending all day at nissan the head mechanic admits there is a problem but cannot say what it is, they sent all diagnostic data to nissan australia for advice and a possible solution answer in 24 hours but this could be a design falt as nissan (my local dealership) tested 3 other vehicles,the same model as
mine and they also have the same problem, so at this stage we don't know what we are facing but at least it will be warranty work,thats what they(nissan) say.
i will post the findings when i have them hopefully tomorrow night
take care
john
298896
Follow Up By: Member - John (Vic) - Wednesday, Apr 16, 2008 at 20:08
A Nissan 3 litre diesel with a design fault???
I don't believe that at all :-)
565079
Follow Up By: Axel [ the real one ] - Thursday, Apr 17, 2008 at 13:04
An 03 , Nissan will fix under Warranty ,, love to see that ,, as pink pigs fly by , lol.
565178
Reply By: Michael ( Moss Vale NSW) - Wednesday, Apr 16, 2008 at 20:32
AHHHH!! the simplicity of the old 4.2tdi...2003
298911
