willow water containers
Submitted: Tuesday, Apr 15, 2008 at 21:25
ThreadID: 56675 Views:3509 Replies:2 FollowUps:3
Hi all,
Has anyone had any problems with water leaking from the screw cap lids while laying their 10/20L willow water containers (blue opaque ones) on their side.
Cheers Greg
Reply By: Oxford - Tuesday, Apr 15, 2008 at 23:13
As a general rule it is always usefull to stand your water containers up if they dont seal correctly.
Having said that, if they are leaking, you might just need to replace the rubber seal in the cap.
AnswerID: 298784
Follow Up By: Member - greg S (QLD) - Wednesday, Apr 16, 2008 at 06:46
Hi Oxford,
Thanks for that.
Might have to try to get a seal or two.
FollowupID: 564947
Reply By: Member - David R (SA) - Wednesday, Apr 16, 2008 at 08:51
I had the same problem. It was due to the top surface of the opening ( the mating surface to the cap seal) being uneven. I solved it by filing the surface smooth. I had first tried a new seal but that was not successful. Hope this helps
AnswerID: 298826
Follow Up By: Member - greg S (QLD) - Wednesday, Apr 16, 2008 at 20:31
Hi David,
Thanks for the heads up on the top surface.
Cheers Greg
FollowupID: 565083
Follow Up By: Richard Kovac - Wednesday, Apr 16, 2008 at 21:43
I'm with you David,
I file the mouth flat, it's the mould lines that are the problem
I file them full them and stand on them to test for leaks.
Richard
FollowupID: 565108
