Cruiser hubs and GU rims ?
Submitted: Wednesday, Apr 16, 2008 at 20:27
Member - Glenn D (NSW)
Hows it going guys,
I am in the market for a trailer as the base for a CT, I want to run the same rims and tyres as the Patrol.
I have seen lots of rims advertised on ebay ( not really factual I know ) suits Patrol or Land Cruiser.
Some trailers I have seen advertised have cruiser hubs , is it reasonable to think they are compatible or will I have to change hubs and get ones to suit my application.
What are others running.
Thanks.
Glenn.
Reply By: Alan S (WA) - Wednesday, Apr 16, 2008 at 20:37
Glenn
The six stud cruiser patern is the same as the nissan. The difference in the rims is the offset.
My trailer has land cruiser rims and the spares will fit the GU but because of the offset they stick out a bit wider.
298915
Follow Up By: Member - Glenn D (NSW) - Wednesday, Apr 16, 2008 at 20:41
Thanks for the quick reply Alan, now I can chase up a trailer tomorrow.
Glenn.
565085
Follow Up By: Alan S (WA) - Wednesday, Apr 16, 2008 at 20:48
Glen
see Phils response below, i have ROH Track II rims not genuine landcruiser so they fit the car and trailer
565087
Reply By: Robin Miller - Wednesday, Apr 16, 2008 at 20:38
Hi Glenn
Just got cruiser 6 stud hubs for my new off-road bike trailer I'm building and it runs my Patrol 16inch rims quite
298916
Follow Up By: Member - Glenn D (NSW) - Thursday, Apr 17, 2008 at 18:25
Thanks , all I needed to know.
Glenn.
565208
Reply By: Member - Phil G (SA) - Wednesday, Apr 16, 2008 at 20:45
Gday Glenn,
The other difference between Patrol and Cruiser
wheels is that the Cruiser's centre hole is a fraction smaller than the patrol. It means that a genuine landcruiser rim may not fit on your patrol. It will have no probs on your trailer, and theres no problem with aftermarket rims.
298920
Follow Up By: madcow - Thursday, Apr 17, 2008 at 07:49
Correct! the hole is about 2mm smaller and given there is a taper you may not see it but it is there and the rim will not
seat properly. BUT they will fit and would be ok on a trailer and be enough to get you out of trouble with regular checking on a vehicle. I fitted 80 series
wheels to a gu with no issues except i had to cut where the centre dress hub used to fit in from the back of the rim and protrude through.
565147
Follow Up By: Member - Glenn D (NSW) - Thursday, Apr 17, 2008 at 18:43
Thanks for the info guys,
Guess I will have to be careful seating the rim on the hub.
Luckily I am not trying to fit Toyota rims to the Nissan , sounds a bit blasphemous to me.
Glenn.
565212
Reply By: smifffy - Thursday, Apr 17, 2008 at 16:00
glenn d,
i have just had a custom made off road motor bike trailer made by an engineering firm in QLD. I told them to fit new rims & tyres to the trailer. they have placed new Sunraysia rims on the trailer that are interchangable with my gu2 2000 patrol (nissan six stud pattern). i now have 2 spares on the trailer & two on the truck, brilliant!
andrew
299031
Follow Up By: Member - Glenn D (NSW) - Thursday, Apr 17, 2008 at 18:24
Hi Andrew,
I will end up with the same set up, plenty of spares.
Glenn.
565207
Reply By: Willem - Thursday, Apr 17, 2008 at 19:53
Glenn
I bought a trailer with Cruiser Hubs. The 6 stud holes are the same size for Nissan. I then changed the studs for Nissan studs and Niussan rims and all my
wheels and wheel nuts are now interchangeable between GQ and trailer. Makes life easy.
299066
Follow Up By: Member - Glenn D (NSW) - Thursday, Apr 17, 2008 at 20:47
Thanks Willem ,
Something I hadnt thought of, I am after as much common stuff as possible.
Glenn.
565241
