Storing Tyres
Submitted: Thursday, Apr 17, 2008 at 07:41
Member - Magic (VIC)
Hubby has just bought a set of new
wheels and tyres for his 4WD and plans to use the road tyres when travelling to work etc, and change to the off-roads when we head off.
My question is, can the
wheels and tyres not being used be stored outside (covered with a tarp) without problem, and, when being stored, should they be deflated?
Thanks in advance.
Reply By: Member - Coyote (QLD) - Thursday, Apr 17, 2008 at 07:54
I do the same thing, but I found that the steel rims Ihad for the off roads trips were starting to get atiny bit of surface rust for obvious reasons so I basically put them inmy carport and chained them to a post. They seem completely fine and unless you are storing them for years at a time I wouldn't bother deflatingthem. In fact the longer you store them the better (within reason). There is one school of thought that basicaly says that the rubber actually hardens a little with age and hence you wil get better mileage out of them, becuase brand new tyres aren't "aged" they are aslightly softer compound and hence will wear a bit quicker in the first few months of their on road life..
298977
Follow Up By: Jasjul - Thursday, Apr 17, 2008 at 08:33
But unfortunately, as the tyres harden and improve tread life, the grip level goes down as the tyres get harder. The rubber is less able to mold to the road surface.
565156
Follow Up By: Member - Phil G (SA) - Thursday, Apr 17, 2008 at 08:51
Our Xtrail's handbook tells you not to use tyres that are more than 6 years old - presumably because the rubber deteriorates with time.
565157
Follow Up By: Outnabout David (SA) - Thursday, Apr 17, 2008 at 18:56
The other thing is that as they get harder they chip more
565214
Reply By: Member - Roscoe ET (QLD) - Thursday, Apr 17, 2008 at 10:55
The tyre dealer I go to told me to air them down to around half normal pressure and to store them in a reasonably cool place.
Fortunately I live on an acreage and have rather a large shed so storage is not an issue
298995
Reply By: Member - Michael J (SA) - Thursday, Apr 17, 2008 at 11:48
Hi Magic,
Supercheap have a wheel storing "tree" for just that purpose.
Have no idea if it is any good in real life, but the theory seems
quite good.
May suit your purpose.
Michael
298997
