Which water filter system ??
Submitted: Thursday, Apr 17, 2008 at 15:02
REV'S
Hi all, It is so confusing with so many
water filter systems there are on the market. Currently I am trying to set up a slide on camper so that we are able to draw
water from creeks, bores etc to fill 0ur
water tanks where
water is available. We do most of our travel through very remote locations. Room isn't an issue, should we use the canister type whether it be 1,2,3 or the 1-micron in-line filter with the silver coated crystals? Has anyone had experiences with these filters negatives or positives?? would be kindly appreciated.
Thanks for any responses.
Cheers Mary Anne
Reply By: Member -Signman - Thursday, Apr 17, 2008 at 15:29
Is this a 'deja vu' from a couple of days ago ??
Or is it Groundhog Day..
299027
Follow Up By: REV'S - Thursday, Apr 17, 2008 at 16:07
Yes ! I did put in a request for information a coupple of days ago and a big thanks to those who responded. From the answers i received it came down to 2 filters . One company menshioned that the inline filters block up very easily and another company menshioned that the canister filter cartridues are quite expensive to replace where as the inline filters just need a reverse flush.
565196
Reply By: Member Boroma 604 - Thursday, Apr 17, 2008 at 16:41
Gooday,
Suggest you have a look at this one bestwaterfilters.com.au, we bought one about a year ago & are happy with it but have not tried it other than town supply, but always use it when filling tanks & using supply direct from mains.
Cheers Boroma604
299037
Reply By: Member -Dodger - Thursday, Apr 17, 2008 at 17:10
We too go into remote locations and fill our
water tanks from streams and other sources as
We check the
water first for any obvious contanimates etc. (dead creatures) and if the
water looks presentable without any nasty smell we then fill our tanks using a small 12v
water pump that has a common garden
water system filter on it.
In the van we have an
Everpure water system and use that for consumable or potable
water.
This filter takes
water from the pressure system and filters it dispensing same by an additional tap over sink. The other
water is taken from the pressure system via the standard Van tap and shower head.
Thus our
drinking water and cooking
water is pure.
The system can be installed very easily by a DIY person and takes only a small space usually under the sink.
Hope that this is not too hard to understand.
In 7 years we have not had the Bali belly bit .
299039
Reply By: Member - Alastair D (NSW) - Saturday, Apr 19, 2008 at 06:41
Mary Anne,
I have used a 1 micron BEST inline unit for a couple of years and am quite happy. As I said the other day I let murky
water settle in a bucket for a while if I have to use it to avoid clogging the filter quickly. The BEST units flush easily by reversing them and letting the watter flow for a while.
I would not go bigger than 1 micron as it will not filter out the nasties.
alastair
299262
Follow Up By: REV'S - Monday, Apr 21, 2008 at 09:34
Thanks for all your help, its helped me a lot. I'll be going for the BEST 1micron as this should do the job.
Mary Anne
565770
