Landcruiser 200
Submitted: Saturday, Apr 19, 2008 at 14:25
ThreadID: 56774 Views:2289 Replies:3 FollowUps:5
Just read a article by "Edmonds.com" in America that states the V8 200 there is fitted with a 6 speed auto the same as fitted to the Tundra. It appears that the buyers here are getting short changed with the 5 speed in the V8 & having to go to the diesel for the extra cog. You would think with the extra torque of the diesel it would be the other way around.
Reply By: Peter 2 - Saturday, Apr 19, 2008 at 15:30
Isn't the 6 speed just a con anyway as the 6th cog doesn't stay in if any accelleration is wanted over a 100k?
Their V8 may be the 5.7 litre not the 4.7 litre.
AnswerID: 299300
Follow Up By: Shane (QLD) - Saturday, Apr 19, 2008 at 15:40
Your right it is the 5.7 3UR- FE all alloy block, just noticed this on "Truck Trend" another Yank site. Still like to see that motor & transmission in our version though.
FollowupID: 565491
Follow Up By: Member - Tony W (VIC) - Saturday, Apr 19, 2008 at 16:58
If you call 9l/100k and 1550rpm in 6th not very useful then it is a huge rip off. If you put down it will go to 5th or even 4th.
Anyone that tells you 6th is no good doesn't own one ...period.
FollowupID: 565496
Follow Up By: Member - Tony W (VIC) - Saturday, Apr 19, 2008 at 17:21
Oops I meant
If you call 9l/100k and 1550rpm in 6th at 100kph not very useful then it is a huge rip off. If you put the foot down it will go to 5th or even 4th.
FollowupID: 565504
Follow Up By: Peter 2 - Sunday, Apr 20, 2008 at 08:56
No worries I know all about big diesel V8's with heaps of torque and getting the gearing to work.
When I first got the Humvee it has a TH400 (turbo 400) 3 speed auto, terminal velocity was 95kph due to 2:1 drop in the portal hubs and fuel consumption was around 18l/100 with the engine doing 2850 rpm, not good.
Eventually I gathered all the required bits to fit the later 4L80E 4 speed with lock up torque converter. At 95kph it is now pulling 1850 rpm, fuel consumption is back to 15 -16l/100 and if I sit on around 105 kph it uses less fuel again as it is right on max torque at 2000 rpm.
FollowupID: 565565
Reply By: PajeroTD - Saturday, Apr 19, 2008 at 23:15
Yes, Landcruisers in the US are fitted with the 5.7 and 6 speed. They wont sell many though, the Sequoia is bigger, has the same running gear, and it's half the price of the LC. Diesel V8 is coming for the Tundra and Sequoia. The 5.7 is available in Australia in the Lexus LX570 only.
AnswerID: 299368
Reply By: GlenJ - Sunday, Apr 20, 2008 at 19:56
There is also a manual box available for the 200 in the Middle east.
AnswerID: 299498
Follow Up By: wdric - Sunday, Apr 20, 2008 at 20:06
We have a customer who's son drives one somewhere over there
FollowupID: 565682
