Nylon winch fairlead rollers
Submitted: Monday, Apr 21, 2008 at 13:45
Parso
Can anyone let me know where u can get the nylon winch fairlead rollers for use with plasma rope?
Reply By: Member -Signman - Monday, Apr 21, 2008 at 13:56
Anyone with a lathe could turn some up for you..Get the right grade material but- the wrong stuff will just bleep ter after a bit of UV exposure..
299622
Follow Up By: Member - Roachie (SA) - Monday, Apr 21, 2008 at 15:09
..................or just go for an aluminium hawse......;-)))
565811
Follow Up By: Member -Signman - Monday, Apr 21, 2008 at 15:31
There's even a polyurethane hawse at about 1/2 the price of the aluminium one !!
565816
Follow Up By: Bonz (Vic) - Monday, Apr 21, 2008 at 17:55
u mean a sore horse Roachie
565835
Reply By: Bonz (Vic) - Monday, Apr 21, 2008 at 17:54
Yep Call Roger Smith, a man who stands below his guarantee:
Contact us
Beadlock Australia Pty Ltd & Dynamica Rope
25 Quamby Road
Ringwood Nth Victoria 3134 Australia
Telephone: 61 3 9876 1511
Facsimile: 61 3 9876 1194
Email: beadlock@bigpond.net.au
Products: Dynamica RopeTM - Ground GrabberTM - SecondAirTM
Australian Distributors for:
DynamicaTM
299672
I got some by the way
565836
Follow Up By: Member - 'Lucy' - Monday, Apr 21, 2008 at 23:29
I wasn't aware that Roger is now selling - sexually transmitted life - but then again, I suppose you are the one and only living prime example of such a thing.
Now that that fact is a known something or other, I will sleep easily tonight.
By the way, are you still looking over your shoulder for that 6'10", 150kg Kiwi SAAB owner, whose vehicle you recently 'panel beated' with the camper van whilst in EN-ZED.
565891
Reply By: Member - Kiwi Kia - Monday, Apr 21, 2008 at 20:59
Hi Parso, How often do you use the winch ? Do you really need to change from steel rollers ? If the steel rollers are in good condition and smooth then I can't see why you need to change.
299709
Reply By: Robin Miller - Tuesday, Apr 22, 2008 at 09:36
Must have to admit I thought about that to get back some efficentcy from my aluminium Hawse.
Seen a friend build one from those plastic rollers from the local trailer place (In Dandenong here its called Carac).
They use them on boat trailers, and they have quiet a range.
Also seen the problem solved with a homemade steel roller which was made such that the horizontal was wide and prevented the plasma from being nicked.
In this case it was just 1 inch steel pipe with large bolt thru centre.
Not as efficent as regular rollers but ahead of Aluminium.
299795
