glow plugs
Submitted: Monday, Apr 21, 2008 at 15:53
patrolmann
Hi guys, being new to diesels i have a 1996 gq 2.8 turbo and the glow plugs light on the dash flashes on for about 10 minutes.
The previous owner said he had a new head and glow plugs and a relay put in about 8 months before i bought it . It has done this since i have had it and just wondered if this is right. Some guys have told me that it should only stay on for a few seconds
Any ideas.
Craig
Reply By: Member - Footloose - Monday, Apr 21, 2008 at 16:14
10 mts ? 10 seconds would be longer than normal unless camped in the ice and snow.
Heuston, we have a small problem.
Lift the strap off each glow plug and check for open circuits.
299652
Reply By: autosparky - Monday, Apr 21, 2008 at 20:46
doesn't sound right these vehicles also have a glow timer module maybe thats at fault
299708
Follow Up By: patrolmann - Tuesday, Apr 22, 2008 at 12:46
Will this c ause any damage to the dielsel running it like this
565965
Reply By: autosparky - Tuesday, Apr 22, 2008 at 13:10
glow plugs running for too long will burn out prematurely , but shoulnt cause any major problems driving, will just keep warming the fuel before combustion, if you have a test light see if they are actually staying on for that length of time. (or multimeter) (one lead to battery neg the other lead to one of the glow plugs
299836
Follow Up By: autosparky - Tuesday, Apr 22, 2008 at 13:35
parolman i say do check them because they may be working fine ,and the cause of the warning light to flash may be another sensor ,ie temp. that may be open circuit and when the motor heats up the light goes out. and the constant flashing might be the fault code to that sensor
565974
Reply By: patrolmann - Tuesday, Apr 22, 2008 at 14:11
thanks for your advice guys. Ill check it out on the weekend
299846
