Cape Dilemma--Muddies or A/Ts?
Submitted: Monday, Apr 21, 2008 at 19:41
ThreadID: 56863 Views:2490 Replies:4 FollowUps:0
Evening all,
i run 285/75/16 Kuhmo venture A/Ts day to day towing and when going of roading(within reason)when i go tripping i usually fit my 305/70/16 Procomp Muddies,recently being a bit lazy i havent been swapping them and only running the A/Ts,have done some swiming,mud bathing and rock climbing even down to 18 PSI and they have been great.we are going up the centre to birdsville then wiggling our way to cape york,normally i WOULD run the muddies but am seriously cosidering running the A/Ts as they are quieter,better on sand and good in everything else.so what do i do--run the normal charter or take the chance with the A/Ts?cheers Paul
Reply By: Batt's - Monday, Apr 21, 2008 at 21:27
It's only my opinion but you can quite easily go to the cape with all A/T's the main worry is the corrigations shaking the hell out of the rest of your 4WD. Make sure you check all bolts around your car run the greese gun over it, carry two spares if you can, don't worry and have a bloody good trip.
AnswerID: 299718
Reply By: Member - Andrew (WA) - Monday, Apr 21, 2008 at 21:57
You've answered your own question.
I did the GRR on A/T's...not one issue.
AnswerID: 299727
Reply By: Towie - Monday, Apr 21, 2008 at 23:09
A/T's should give you no probs... i run cooper A/TR's 265's
We run up and down the Bloomfield and Creb track up here with no worries....... and have a great time we will be up the Cape ourselves in mid June and running the Coopers 265s...
AnswerID: 299745
Reply By: Cape York Connections - Tuesday, Apr 22, 2008 at 06:33
You can run what you like as long as they have plenty of life left in them.
All the best
Eric
AnswerID: 299769
