Engel information please
Submitted: Tuesday, Apr 22, 2008 at 14:41
ThreadID: 56888 Views:9070 Replies:4 FollowUps:13
I have been given an Engel which must be about 20yrs old and is approximately 12 litres. The manufacturers plate is almost obliterated but I can see what looks like "Model ..FT 515A A4" . Does anyone know how many amps it draws and if itwould be too dangerous to run it off the ciggy lighter conn. with the unit in the ute tray, i.e will it suck too many amps? Thanks
Reply By: Member - joc45 (WA) - Tuesday, Apr 22, 2008 at 14:56
If it's the old 14L, it has the condenser on the side of the fridge, sort of exposed. Draws about 5A, would be no problems running it from your ciggy lighter. Very early ones (early 70's) were a bit hotter on current.
Gerry
AnswerID: 299851
Reply By: Member - bushfix - Tuesday, Apr 22, 2008 at 14:59
G'day mate,
could be up to around 7.5 A so fine for ciggy socket but be on the lookout for it "shaking: out thus warming your tinnies unbeknownst to you!
but give Engel a call on 1300 302 653 anyway. Good, tough old unit.
AnswerID: 299852
Reply By: Kev & Darkie - Tuesday, Apr 22, 2008 at 14:59
It sounds like it is an old 15 litre unit and will draw about 4.5amps.
It shouldn't be that hard to get a new lead to replace the cig lighter plug to a more positive connection as the cig lighter plugs have a habit of comming loose.
Cheers Kev
Russell Coight:
AnswerID: 299853
Reply By: deserter - Tuesday, Apr 22, 2008 at 15:59
My 40L comes with a cigarette plug - I therefore assume it can be used with a normal car cigarette socket ?? Wouldn't that one be the same ??
AnswerID: 299861
Follow Up By: mowing - Tuesday, Apr 22, 2008 at 19:48
Hi Deserter, It would but what Kev was saying is that the "new" plugs provider greater contact and hold the connection better when things get rough or an item that is in the back of a S/Wagon for instance moves and dislodges the cigarette lighter plug.
Mark
FollowupID: 566059
Follow Up By: Member - Phil G (SA) - Tuesday, Apr 22, 2008 at 20:18
Deserter,
Your 40litre has the new compressor that only pulls 2.8Amps when the compressor is running, so easily runs off cig socket.
All the old A series Engels pull 6.0 Amps, which is borderline for the average cig socket (they get hot).
FollowupID: 566070
Follow Up By: wigger - Tuesday, Apr 22, 2008 at 21:07
Thanks Guys, since several of you think that it's a 15 litre unit and there is a"15' in the plate designation, then this is probably what is is. I just ran a tape ovet the bin and cubed it, getting 12itres l but Engel might have upped the figure. Is there a way of actually measuring the amps drawn so that you don't stuff up or do you always have to get this figure from the manufacturer(or label plate) If the ciggy socket gets hot should I just pull it and get a direct battery connection made up?
Despite it's age it goes very well and will drawn down to minus 13
so I just can't bring myself to chuck it.
FollowupID: 566092
Follow Up By: wigger - Tuesday, Apr 22, 2008 at 21:10
How do I post a picture of the unit and the lead I've got
FollowupID: 566094
Follow Up By: Member - Phil G (SA) - Tuesday, Apr 22, 2008 at 21:19
Wigger,
To measure amp draw, use an ammeter - most Digital Multimeters will measure up to 10 amps. Just follow the instructions, which usually means you put the red lead into the 10AMP socket and turn the dial to the 10AMP setting. The two leads need to be in series to measure current.
If you like, here is the advert from a 1991 brochure which is the following model (B series). Maximum draw is listed as 3.7 Amps per hour (the compressor doesn't cycle continuously). But the Engel figure for the A series was 3.9, which usually means the compressor draws 6amps when running.
Image Could Not Be Found
I've fitted a fan to my old B-series - you can get a circuit diagram off the net, that turns a 12V fan on whenever the compressor is running. I don't use cig sockets for fridges - too unreliable - theres plenty of good alternatives - merit plugs, Anderson plugs, deans ultraplug etc
FollowupID: 566096
Follow Up By: Member - Mick O (VIC) - Tuesday, Apr 22, 2008 at 22:27
Phil, where did you come up with the brochure from? That's pure gold! I bought my first Engel in 1984, actually I traded my goat gun (Remington Mohawk .222) for it. Vintage. I'd even forgotten what it looked like till I saw this.
Cheers. Mick
FollowupID: 566116
Follow Up By: Member - Phil G (SA) - Tuesday, Apr 22, 2008 at 22:46
Mick, I'm a hoarder!!
Its the brochure from when I bought my first Engel. Had spent years before that trying to make 3-way fridges work!!
39L Engel cost $870 (with discount) in 1991.
FollowupID: 566122
Follow Up By: wigger - Tuesday, Apr 22, 2008 at 23:09
Phil, Thanks It looks just the same as that MRFT 515 in the catalogue. Can you enlighten me as to why you fitted a fan and under what circumstances anyone else would need one?
FollowupID: 566135
Follow Up By: wigger - Tuesday, Apr 22, 2008 at 23:12
Got it . It's obvious that the case lettering reads "MRFT515A" so
it draws 6amps as you said.
FollowupID: 566137
Follow Up By: Member - Mick O (VIC) - Tuesday, Apr 22, 2008 at 23:15
Frightening but true. Considering I was earning about $240 a week back then, it was a bloody HUGE investment. I remember it cost me a months wages but on my first trip out over the Gunbarrel in 1985, the ability to carry Fresh (frozen) meat was a luxury beyond measure. Actually, the Engel cost me more than my matching Westinghouse fridge and freezer combo! lol. Mind you my Nissan 720 Kingcab 4x4 only cost $9800! Sheeet, the fuel on this years trip to Rudall is going to cost more than that!
M.
FollowupID: 566138
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 23, 2008 at 13:43
Wigger,
A fan improves the efficiency of the fridge - it will use less power overall if its in a confined space.
The fan only draws about 0.15amp, but the compressor doesn't need to cycle as long, if the warm air is pushed away by the fan. In the back of a ute, it may not make much difference.
http://www.gpsoz.com.au/faninstall.htm
FollowupID: 566224
Follow Up By: wigger - Monday, Apr 28, 2008 at 13:38
Phil, thankyou for the wiring up guff. It is very helpful. I was also going to get some polystyrene sheet and do a 3 way wrap, excluding the meshed area, because the fridge will be on the back of a ute. is this OK . Ask the question because on house fridges with no coils on the back there is a heat transfer through the walls and I don't want to impede this, obviously, if the Engel works on the same principle.
If you're near M'bah call in for a beer. E/M contact "donnedx@hotmail.com
FollowupID: 567024
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 30, 2008 at 07:05
Wigger,
Adding an extra layer of insulation around the outside works well, and probably better than the bags they sell these days. My newer fridge has the 1cm thick square floor mat glued around three sides and underneath as well. Got the mat in a pack of 4 from supercheap - and just used contact adhesive to attach it. Looks pretty neat too. I didn't bother with the lid, but you could do that too. I would have done it to both my fridges, but the extra 2cm of width meant it won't fit inside my canopy.
I'll keep you in mind for Muwullimbah, but won't be that way this year.
phil
FollowupID: 567327
