Gas regulator on swan campervan.
Submitted: Wednesday, Apr 23, 2008 at 20:00
ThreadID: 56937 Views:2701 Replies:4 FollowUps:2
Hello
We bought a jayco swan a little while ago (2005 model). I havent been able to get the gas going in it, and today I realised gas wasnt getting through the regulator. It has a regulator which I havent seen before, 2 seperate parts to it.
Anyway, my neighbor gave me a new regulator to use on it, but its just your standard bbq regulator you use on the 9kg bottles. So just wondering if anyone knows if I need to replace the fancy regulator or I can just use the common type?
The other question regarding regulators is about a little portable bbq I bought from the hardware shop. It says you have to use 3kg max bottles on it and I was wonderign if I can just put a regulator on a 9kg bottle and use that on it?
I know this isnt a bbq forum but with all the knowlegeable campers on here I know you guys will know the answer.
thanks
regards
Justin
Reply By: gerrybhoy - Wednesday, Apr 23, 2008 at 20:41
g'day justin;
the first little part is an excess pressure device to protect installation/appliances from excess pressure. Although the bbq reg will work it is not legal.
AnswerID: 300163
g'day justin;
AnswerID: 300164
Reply By: Member - Kim M (VIC) - Wednesday, Apr 23, 2008 at 20:59
Justin
I won't go into the history of this, just get your self a new a copper pig coil. The problem is in the hose, not the regulator.
Kim
AnswerID: 300176
Follow Up By: justin71 - Wednesday, Apr 23, 2008 at 22:18
Hi Kim
When I disconnect regulator side of hose though the gas gos through it, still replace it?
FollowupID: 566338
Reply By: Member - Kim M (VIC) - Wednesday, Apr 23, 2008 at 22:39
Justin
Give me a ring at work tomorrow on (O3) 97055467. It will only take two minutes of talk to fix the problem. After that you'll be ok.
Kim
AnswerID: 300194
Follow Up By: justin71 - Wednesday, Apr 23, 2008 at 23:28
Will do, thanks a lot Kim
regards
Justin
FollowupID: 566347
