long range fuel tank
Submitted: Saturday, Apr 26, 2008 at 08:15
dustmike12
where can i pick up a 126 lt
tank for a 99 hilux 2.7 at a reasonable price. they seem to be rather expensive $1100.00 fitted.
in
Adelaide .
Reply By: Member - Matt & Julie (VIC) - Saturday, Apr 26, 2008 at 09:42
Hi Dustmike 12
I have just replaced a
tank in my vehicle which I purchased from 4wd systems in
Adelaide, I looked at a lot of sites but I found them to be the best for two reasons ,construction all made from I think 3mm steel and has a neet finish,price tag of $800 to my door .one place hear in
melbourne wanted just over $1000 for a
tank 12 litres less, if you are like me and have a spare car you will have extra time and you can fit it yourself and save $.
300550
Reply By: dustmike12 - Saturday, Apr 26, 2008 at 14:04
thanks mate good one ill follow it up
300579
Reply By: GlenJ - Saturday, Apr 26, 2008 at 21:48
Are they made of some sort of steel that wont rust.
Or just plain stuff?
300678
Follow Up By: dustmike12 - Saturday, May 10, 2008 at 19:38
i did a bit of ringing around some tanks that are mild steel only
could rust on the inside if contaminated fuel get in.
569255
Follow Up By: GlenJ - Saturday, May 10, 2008 at 20:52
Yeh they might look like good value and work fine for a while, but then when you inevitably get a bit of moisture in there they will start to rust and clog filters etc
If you can only afford a cheap one, you probly can't afford to fix things later.
There should be some sort of standard for this sort of thing, imagine buying a car which was painted on the outside but unpainted were you cant see it :(
569274
Follow Up By: GlenJ - Saturday, May 10, 2008 at 20:57
Were I work they use gal sheet for cabinets etc and there is a price rise of 25% this month, and this has to be passed on to the customer, but you do get what you pay for I guess
569275
Reply By: Member - John - Monday, May 05, 2008 at 20:29
Try this link
Long Range Fuel Tank
302206
Follow Up By: dustmike12 - Wednesday, May 07, 2008 at 20:13
hi john
thanks for the link, been green about 4x4 stuff i can only say
that the people on this
forum are great.
regards mike
568638
