Long Range Tank
Submitted: Saturday, Apr 26, 2008 at 23:14
Member - Stuart W (NSW)
I'd like a long range fuel
tank to fit my 2003 dual cab diesel hilux. I would appreciate any opinions on best value/reliability etc.
Thanks Stuart.
Reply By: Chris@forum - Sunday, Apr 27, 2008 at 02:32
hi start
here a flew links I found by looking for tanks for a HZJ79
thelongranger.com.au
I guess thouse guys are quite into the business
and I found longrangeautomotive.com.au
Chris
300700
Reply By: Chris@forum - Sunday, Apr 27, 2008 at 02:34
hi Stuart
here two links I found by looking for tanks for a HZJ79
but I have no experiences so far
Chris
300701
Reply By: Cape York Connections - Sunday, Apr 27, 2008 at 07:25
Just have a good think do you realy need a long range
tank.
All the best
Eric
300709
Reply By: Member - John G- Sunday, Apr 27, 2008 at 09:54
G'day Stuart
We have a Longranger
tank (115 litre) fitted to a 2000 Hilux. It was fitted in 2004 and we haven't had any problems at all. The increase in range when towing is a huge advantage.
One thing to note - the fuel guage does not start operating until the
tank level gets to 66 litres (the capacity of the original
tank). After discussion with the folks who fitted the
tank, and after they had discussion with Longranger, we were told that this is the way it is
300722
Follow Up By: porl - Sunday, Apr 27, 2008 at 10:24
Does the spare tyre need to move for these?
thanks
566854
Follow Up By: Member - John G- Sunday, Apr 27, 2008 at 11:28
G'day porl
Not for the Longranger on the 2000 TD Hilux dual cab. Fits almost directly behind/under the fuel filler pipe. Can't spk for other models/years.
One thing to think about (which I didn't) - we have a dual battery system, with the second battery in the back because it wouldn't fit anywhere in the engine bay. We finished up with the bigger fuel
tank and the second battery on the same side. Doesn't really seem to affect anything but ideally for weight distribution it would be better to have the battery on one side and fuel
tank on the other.
566867
Follow Up By: Member - Porl - Monday, Apr 28, 2008 at 09:11
Thanks John
I've got the non-turbo 2000 dual cab diesel so thanks for the confirmation.
566985
Reply By: Member - John - Monday, May 05, 2008 at 21:06
Reply By: Gramps (NSW) - Tuesday, May 06, 2008 at 17:27
Looked at this a while back for my petrol Hilux. The long range tanks available then replaced my current 77 litre
tank but only added a maximum of 50 litres i.e. 127 litres in total.
The maths of 3 jerries against around $1,000 for the long range
tank decided the issue. If you're sensible, carrying a few jerries is not a risk at all. For a diesel vehicle it is an even better solution IMHO.
302365
