Troopy Stuck in Neutral
Submitted: Sunday, Apr 27, 2008 at 20:41
ThreadID: 57050 Views:3383 Replies:7 FollowUps:7
Came home through fourteen 40-50cm water crossings in 7 km. (creek was up due to a foot of rain this month). Last crossing is just 100 metres from garage.
Troopy was then parked two days in gear with handbrake off.
When attempting to leave this morning, I shifted to neutral, switched engine on, and discovered I could not engage any gear. If i forced the gear stick forward (still not into gear) the car would edge forward.
Discovered that I could easily shift to any gear with the engine off. Therefore engaged reverse and started car in gear without clutch. It reversed and had to be stopped by engine switch-off. Then I engaged 1st gear and started engine with same effect.
This process fixed the problem - gear changes feel 'as new'.
Question - what was likely cause and how can it be stopped?
Chris
Reply By: TD100 - Sunday, Apr 27, 2008 at 20:47
Chris,
at a guess the clutch plate stuck to either the flywheel or the pressure plate or both!bit of a clutch ride and it will clean itself up.cheers Paul
AnswerID: 300825
Follow Up By: Member - Chris R (NSW) - Sunday, Apr 27, 2008 at 21:01
Thanks for advice Paul and Phil.
Sounds like I should do an 'extended' clutch ride on the hill to the garage once I've cleared the crossing.
Best regards
Chris
FollowupID: 566928
Reply By: Member - Phillip S (WA) - Sunday, Apr 27, 2008 at 20:52
I agree...it was your clutch plate that got stuck
AnswerID: 300827
Reply By: Affordable Batteries & Radiators - Sunday, Apr 27, 2008 at 21:01
Clutch plate or pilot bearing is a bit rusted.
Try start the car in gear with the clutch depressed. It should start and release the rust but if the clutch is noisy or rough after a quick drive have the clutch and bearing checked.
Derek.
AnswerID: 300829
Follow Up By: Affordable Batteries & Radiators - Sunday, Apr 27, 2008 at 21:03
P.S. Handbrake and foot brake ON !
FollowupID: 566929
Follow Up By: Member - Chris R (NSW) - Monday, Apr 28, 2008 at 07:47
Thanks Derek
Youv'e given same answer - and I'm sure it's right - wet cool clutch allowed to rust into position over a couple of days. In my case, starting did not release it. No unusual noises. Could not move the gear selector with engine running.
Cheers Chris
FollowupID: 566968
Reply By: autosparky - Sunday, Apr 27, 2008 at 22:59
was gear box noisy at any time before this , maybe 2nd or 4th gear? had a similar problem was the connector shaft between transfer case and gearbox
AnswerID: 300852
Follow Up By: autosparky - Sunday, Apr 27, 2008 at 23:32
was it difficult to get into 2nd or top gear?
FollowupID: 566951
Reply By: Member - Doug T (FNQ) - Sunday, Apr 27, 2008 at 23:46
I see your learning , I had that while i was living in Perth , just once, never done it again since .
AnswerID: 300865
Follow Up By: Member - Chris R (NSW) - Monday, Apr 28, 2008 at 07:52
It's a potential prob here whenever the creek is up - and suspect it's a good reminder for anyone fording and camping in the wet.
I learnt long ago not to leave handbrake on - or alternatively to dry brakes right out - after deep water, but this one took me by surprise
Cheers Chris
FollowupID: 566969
Reply By: Member -Signman - Monday, Apr 28, 2008 at 08:36
I often have problems getting back into 2WD out of 4WD- dunno if it internal or external linkage. A few swear words generally fixes it.
Also, the handbrake ain't worth a pinch of poo. Have it adjusted up all sweet, but within a few weeks it doesn't hold !!
AnswerID: 300893
Follow Up By: On Patrol (East Coast) - Monday, Apr 28, 2008 at 18:45
Dave, maaate
You know how to solve those and many other problems. Get a Patrol. HeHeHe.
FollowupID: 567090
Follow Up By: Vivid Adventures - Monday, Apr 28, 2008 at 19:15
and my mechanic says Nissan have moved to the same dumb-assed hand-brake design as tojo...
That is funny.
Mine needs cleaning out and adjusting every trip.
FollowupID: 567099
Reply By: troopyman - Monday, Apr 28, 2008 at 09:15
Its safer to put a brick behind the troopy tyre than to rely on the handbrake .
AnswerID: 300903
