Coleman HWS feedback
Submitted: Monday, Apr 28, 2008 at 16:17
Kev & Darkie
What is the current feedback on the updated Coleman HWS. There has been comments previously that the older models had a few issues. Have they fixed these issues with the new one??
I am looking at getting one prior to
Innamincka.
Cheers Kev
| Russell Coight:
Reply By: Member - Olcoolone (S.A) - Monday, Apr 28, 2008 at 16:23
Ours is about 12 months old and have not had a problem with it.
Anaconda has them on special at the moment.
The older one had I think a 10 year warranty and the new one has 12 months.
Regards Richard
300971
Follow Up By: KiwiAngler - Monday, Apr 28, 2008 at 16:43
wow
10 years down to 12 months!!!
Something has changed - they must be 1) getting them made from a different aprt of the world (China probably) and/or they have had so many 'issues' they have had to drop the warranty
Wonder which/what??
567061
Follow Up By: Kev & Darkie - Monday, Apr 28, 2008 at 16:44
Probably both unfortunately
| Russell Coight:
567063
Reply By: Brew69(SA) - Monday, Apr 28, 2008 at 16:25
Yeah all good from our point of view.
300974
Reply By: Shaker - Monday, Apr 28, 2008 at 16:37
All good here too.
$298.00 at KMart at the moment.
300975
Follow Up By: Kev & Darkie - Monday, Apr 28, 2008 at 16:38
That's a bloody good price, that's about $100 off.
Cheers Kev
| Russell Coight:
567059
Follow Up By: Kev & Darkie - Monday, Apr 28, 2008 at 16:43
If that was part of the 25% off
camping stuff in the Catalogue then it ended yesterday :(
Cheers Kev
| Russell Coight:
567060
Reply By: Kiwi & "Mahindra" - Monday, Apr 28, 2008 at 16:46
Great minds think alike....but in our case....crazy minds think alike!
We're looking at one too, but the way bills are going at the mo I might be owing you the rums ! N O T ! !
I think these go for pretty cheap, I think!
let me know how you go and Ill figure us out....
300976
Reply By: Trevor R (QLD) - Monday, Apr 28, 2008 at 17:10
Kev,
I got a cheaper version of the Coleman from repco or supacrap or something like that for 80 bucks and I reckon it works a treat. I have had a shower under a coleman and this "Black Ridge" works equally as good in my opinion. (Still not as good as my Glind though). There is one difference between the two gas showers and that is the "Black Ridge" is best used to heat
water then use it only as a pump and shower to shower under cause if you stop the
water flow, the gas cuts out and you are back to pumping source
water temps, if this is cold then so is your shower....so heat source
water then jump in for a shower and all is good.
Cheers, trevor.
300982
Follow Up By: Member - Craig M (QLD) - Monday, Apr 28, 2008 at 17:52
Howdy,
Bought
mine from Kmart.
Check to see what is included. There is a skinny version without the gas hose, shower and cylinder. Will add about $46 to the skinny price if you have to buy them seperately. Used
mine on the weekend. Works a treat. Pity the pump doesn't fit into a 20lt jerrycan otherwise it would be perfect. The 10lt soft collapsible thing is a bit of a pain to fill and lug around. Looked at the Primus as
well. Seemed a little 'cheap' in the construction so gave it a miss. Probably performs ok.
Craig
567077
Follow Up By: Trevor R (QLD) - Monday, Apr 28, 2008 at 19:23
Hi Craig,
Mine included gas hose and shower head but no bottle. Don't know if it is the "skinny" or "fat" version but with my "skinny" wallet I probably got the "skinny" version :-))))))
Agree with the mongrel pump that does not fit in the 20lt jerries, but neither does the Coleman or Primus from recollection. Crab cooking pot fixes this as source
water pot and has enough
water for two showers (1/4 for me and 3/4 for her LOL!!).
Cheers, Trevor.
567100
Follow Up By: Kev & Darkie - Monday, Apr 28, 2008 at 19:42
An issue I have with using it for a shower is that you need to use potable
water. I think that it would be ok when there is a reliable potable
water source but what about when there isn't?
Cheers Kev
| Russell Coight:
567105
Follow Up By: Trevor R (QLD) - Monday, Apr 28, 2008 at 20:04
Sorry Kev, not sure what you mean. Do you mean
water is wasted if not all used for the shower? If so, why not put any leftovers back in a Jerry when it cools? OK then to use in next shower???? this is what we do.
Cooper
water will do me for a
water source for a shower when out that way and I sure as eggs will use my little gas setup for showers when out there. At 80 bucks if this prematurely deteriorates the shower then so be it. I can buy four of these to one Coleman. As always, each to their own.
Cheers, trevor.
567113
Follow Up By: Kev & Darkie - Tuesday, Apr 29, 2008 at 05:59
Trevor,
It is what Adrian has explained below, Sam wants to use the HWS to heat
water for cooking etc and was concerned about using non potable
water through it for showers.
Cheers Kev
| Russell Coight:
567177
Reply By: AdrianLR (VIC) - Monday, Apr 28, 2008 at 22:33
Hi Kev
Ours is great.
I replaced the cap that goes on the pump that goes on the collapsable bottle with a cap from a 20L Jerry through which I drilled a hole and put a new washer inside. This way I just put it on a Jerry that lies on its side with the pourer down. No waste.
For "non-potable"
water (I assume you mean dirty but not toxic) I put a stocking over the pump before putting it into the
water. No problems with Murray
water. If the
water's too rank you wouldn't want to use it for a shower anyway. No taint afterwards with
drinking water but you need to flush with clean
water out of a bucket so that dirty
water doesn't flow back out of the hose into a jerry can.
Only use it when we take the Trak Shak as it's a bit bulky otherwise. Great for a quick wash and saves a lot of gas by pre-heating cooking
water for pasta etc. Get a MacCoupler to refill the "disposable" gas canisters.
Adrian
301084
Follow Up By: Kev & Darkie - Tuesday, Apr 29, 2008 at 06:02
Adrian,
That's exactly our concern about water, but it seems that you have a good method of reducing contamination.
Cheers Kev
| Russell Coight:
567178
Reply By: Member - Warfer (VIC) - Tuesday, Apr 29, 2008 at 01:48
I replaced that bleep ty black sprayless shower head with one from bunnings and it feels like the one at
home !
Wack it over a branch,Nude Up and Sing ,Oh when the Saints come marching in !
301093
Follow Up By: Kev & Darkie - Tuesday, Apr 29, 2008 at 06:04
Can more than 1 person fit under the Bunnings shower head?? Cause if they can then I'll be singing something better than "when the saints come marching in" LOL
Cheers Kev
| Russell Coight:
567179
Reply By: Ozboc - Tuesday, Apr 29, 2008 at 08:09
we have a Primus , (new version ) and like it - the only thing i would change is maybe bumping up the water rate ( LPM ) apart from that you can feed it with very cold water and it heats it easily first go
we use a Garbage bin to hold the water - which we get from the river where we
camp. also have the colman tent :)
kids love it -- misses loves it --- now going away for a week away from civilization and hot showers is no longer an issue :)
Boc
301103
Reply By: OZGEORGE - Tuesday, Apr 29, 2008 at 08:22
Pity you are in the wrong state. I have one i am going to sell complete with bag, shower attachment, gas hose and a maccoupler to refill the bottles.
301104
Follow Up By: OZGEORGE - Tuesday, Apr 29, 2008 at 08:24
Unless you are coming via
Adelaide lol.
567190
Follow Up By: Kev & Darkie - Tuesday, Apr 29, 2008 at 08:29
Depends on if you want to post it ;)
send me an email to kevndarkie@hotmail.com with details and I have a chat with the minister of Finance.
Cheers Kev
| Russell Coight:
567191
