Codan 9350 Autotune Issue
Submitted: Monday, Apr 28, 2008 at 18:21
ThreadID: 57082 Views:7084 Replies:6 FollowUps:20
Hi there,
A question for anyone who has the above antenna.Mine has been working perfectly until our trip this past week. Whenever I trued to tune my antenna it beeped at me with a failed message on the screen. Once driving for a while it seemed to tune ok without any problems.
It indicated to me a power issue, but the question is why all of a sudden. Nothing in the truck has changed. Same battery, same fridge, same radio, same wiring, but suddenly these problems.
if anyone has any suggestions as to where to start to look to resolve this it would be most appreciated.
Richard
Reply By: blue one - Monday, Apr 28, 2008 at 18:28
Richard,
That's quite normal to get the 3 deep beeps when it won't tune. Can be ionisphere,
AnswerID: 300997
Follow Up By: blue one - Monday, Apr 28, 2008 at 18:31
Let me try that again
Richard,
That's quite normal to get the 3 deep beeps when it won't tune. Can be ionosphere, interference, hills etc etc. Usually if you try it straight away again it will tune.
Happens to mine occasionally too.
FollowupID: 567085
Follow Up By: Member - RFLundgren (WA) - Monday, Apr 28, 2008 at 18:36
Yeah I have had that before, but when it happens every single time across 10 days there is definately something not right there.
Richard
FollowupID: 567087
Follow Up By: blue one - Monday, Apr 28, 2008 at 18:42
Is the earth clean?
FollowupID: 567089
Reply By: jdwynn (Adelaide) - Monday, Apr 28, 2008 at 18:38
Richard
I agree with Blue One, but just as an occasional thing. However, if its happening everytime as you say then something might be adrift. What series is it / how old? cheers JD
AnswerID: 301003
Reply By: Member - John (Vic) - Monday, Apr 28, 2008 at 18:41
Earth issues???
Footloose is the man you want, he will be along shortly, I'm sure :-)
AnswerID: 301006
Follow Up By: Member - RFLundgren (WA) - Monday, Apr 28, 2008 at 18:54
Hi John
I initially though it may be an earth problem, and it could still be, however after driving for about 30 minutes it seemed to tune just fine, so I suspect some kind of power issue, as I believe that they do suck quite a bit when tuning.
I will wait to see what light footy can shed on it :)
Richard
FollowupID: 567094
Follow Up By: SteveL - Monday, Apr 28, 2008 at 20:32
You could test it with another autotune.I have one lying around the house. -Steve- Whisky 8528
FollowupID: 567125
Reply By: Member - Footloose - Monday, Apr 28, 2008 at 21:09
All is not well with either your installation (earths) or your aerial.
Earths are relatively easy to check.
If it's not earths then check out this link, Simple 9350 service
AnswerID: 301050
Follow Up By: Member - John (Vic) - Monday, Apr 28, 2008 at 22:12
There you are, where ya been Footy???
This blokes been sweating on your advice :-)
FollowupID: 567137
Follow Up By: Member - Footloose - Monday, Apr 28, 2008 at 22:24
Hi John. Where've I been ? I'm not sure, last time I looked at the puter clock it was 8.30 and now it's 10.20!
FollowupID: 567139
Follow Up By: Member - RFLundgren (WA) - Monday, Apr 28, 2008 at 22:48
Footy
All was going well until this last trip. I did find on the way home from work today that if I turned the fridge off the antenna did seem to tune more readily than if the fridge was running. I did also notice that my fridge was not cold this afternoon either, and even though it was empty it still shouild have had some coldness in it. It did however work well on the trip, swo I am still thinking something to do with power?
Richard
FollowupID: 567145
Follow Up By: Member - Footloose - Monday, Apr 28, 2008 at 22:55
Richard...ahhhh...yes power. Your battery sounds like it's on the way out.
FollowupID: 567149
Follow Up By: Member - John (Vic) - Monday, Apr 28, 2008 at 22:55
Battery stuffed Richard???
Have you tested it to ensure its ok?
FollowupID: 567150
Follow Up By: Member - RFLundgren (WA) - Monday, Apr 28, 2008 at 23:03
Battery should be more than fine. Almost a new (< 6 months old) Full River 90AH AGM. Maybe it doesnt like being under the bonnet. When I get the chance I will pop back to where I purchased it from and have them do some investigation on it for me. May have to go back to a standard wet cell battery under the bonnet that will stand the heat better me thinks.......
Richard
FollowupID: 567155
Follow Up By: Member - Footloose - Monday, Apr 28, 2008 at 23:17
Does the NGT menu have an option for displaying the battery voltage, similar to the 9323? If so, check it on transmit. I'm betting that you'll get around 11.4 volts.
Yep, get them batteries checked.
FollowupID: 567162
Follow Up By: Member - RFLundgren (WA) - Monday, Apr 28, 2008 at 23:21
Footy
Yeah it can show the voltage, although I dont know about on transmit. Pressing button 1 to bring up the tune screen also shows the current Voltage. On driving it is sitting around 13.7 - 13.9 which is to be expected. When I got home tonight after about 60 minutes in the car, let the car sit for a while after turning off and voltage was reading 12.5
Richard
FollowupID: 567164
Follow Up By: Member - Footloose - Monday, Apr 28, 2008 at 23:33
See if it drops on transmit...I'm betting that it will drop considerably.
FollowupID: 567170
Follow Up By: Member - RFLundgren (WA) - Wednesday, Apr 30, 2008 at 17:58
Hey Footy
Cant see the voltage screen on transmit. If I leave it on that screen it just wants to tune again.
As far as earths go, the only one I can see on the tuner itself is the large metal ribbon type cable that goes from underneath to an earth point on the car. Anywhere else I should be looking?
Richard
FollowupID: 567440
Reply By: Member - Olcoolone (S.A) - Tuesday, Apr 29, 2008 at 09:24
Remember the 9350 has two earth straps one where the rubber vibration mounts are earthing the the top and bottom plate (6mm wire).
The second earth point is from the base of the mount to the vehicle (big eart strap).
If the antenna has to be tuned from one frequency and the other frequency is along way apart it may not tune the first time, example from 14 Mhz to 5 Mhz.
The other thing is is your antenna is a "A" or "B" series there may be a proble internaly with it...they had known problems.
Most "A" and "B" series have been repaired by now and upgraded to a "C" or "D" series.
Regards Richard
AnswerID: 301115
Follow Up By: Member - RFLundgren (WA) - Tuesday, Apr 29, 2008 at 17:34
I will check what series it is when I get in this afternoon and report back tonight.
Richard
FollowupID: 567251
Follow Up By: Member - RFLundgren (WA) - Tuesday, Apr 29, 2008 at 20:19
Ok its a "D" series so that should be good.
Richard
FollowupID: 567280
Reply By: The Geriatric Gypsies - Wednesday, Apr 30, 2008 at 17:33
goodday richard
had mine in for testing testerday similar problem radio and aerial just 12months old aerial has now been removed as there is a problem with it not self tuning but an off shoot to this problem they say my aerial is to close to the roof rack but i have never had a problem like this beforeand i may have to use a centre of spare wheel type mounting to move away from the rack ?? but a definite problem with the tuning
it started with channel 2 but then got worse on channel 1 also was discussed that using just 1 channel could cause a hotspot which would do the same thing
steve
AnswerID: 301346
Follow Up By: Member - RFLundgren (WA) - Wednesday, Apr 30, 2008 at 17:52
Hi Steve
I have not had this problem before. Had the antenna mounted in the same spot for the past 3 1/2 years with no issues.
It fails first and then eventually decides to tune. I thought maybe power, although I left the fridge running all last night and it was cold this morning, so the battery should be ok.
At the moment I am still at a loss. I will try to call into a sked tonight to make sure it is transmitting ok, and if that is good then I am still up for some further suggestions.
Richard
FollowupID: 567436
Follow Up By: The Geriatric Gypsies - Wednesday, Apr 30, 2008 at 18:44
goodday richard
sounds the same as mine and when we took it to the dealer the harder he worked the channel changer the more it started failing more often until it failed everytime after about an hour of testing
steve
FollowupID: 567450
Follow Up By: Member - RFLundgren (WA) - Wednesday, Apr 30, 2008 at 20:55
Steve
Mine seems to want to work after about 2 - 5 minutes of turning on. I did call into Adelaide base this afternoon and was told I sounded like I was next door to him so at least the radio itself seems to be working just fine.
Will have to check the earth connections, although I would think that if it was a bad earth it would tend to be more unreliable than it currently is, so hoping it is not the autotune itself :(
Richard
FollowupID: 567470
