motor keeps running
Submitted: Monday, Apr 28, 2008 at 19:14
ThreadID: 57086 Views:1979 Replies:5 FollowUps:4
Went to turn off the 04 diesel turbo mitsubishi canter today and it still chugged a couple of times. turned it off and on a couple of times and still did it until it just keeped on running till i had to stall it. Been on corro roads for a couple of days me think some thing to do with fuel pump but the cook thinks i think to much and dont know enough. Any ideas would be great as im away from a mechanic THANK YOU in advance. Tony
Reply By: garthyguts - Monday, Apr 28, 2008 at 19:19
did same thing on my hilux 2.8d,fuel pump stuck on.
sprayed with wd40 now ok.
AnswerID: 301022
Follow Up By: balko - Monday, Apr 28, 2008 at 20:17
GREAT i hope its that easy thanks
FollowupID: 567117
Reply By: howesy - Monday, Apr 28, 2008 at 19:31
Not familiar with the canter motor. Has it got the old inline pump or the centrifugal pump.
The inlines usually had a solonoid pushing a rod to activate the stop lever.
The centrifugal pump usually has a small electronic solonoid screwed in that cuts the fuel. I would suggest that the solonoid is sticking or the relay is or you have a dodgy connection in the cicuit after the rough ride.
It should be an easy and cheap enough fix and nothing to worry about.
The old pumps you could just pop the rod off and move the lever to the stop position when the F#@ked up
AnswerID: 301026
Follow Up By: balko - Monday, Apr 28, 2008 at 20:20
Yes Howesy its the old inline pump so first light in the morning ill have a look thanks for the tip atleast now ive got some where to start Cheers Tont
FollowupID: 567118
Reply By: F4Phantom - Monday, Apr 28, 2008 at 19:58
I can guarantee what I am about to suggest is not your issue but I cant think of a better thread to bring it up. On worn diesels engine oil can leak into the cylinders and keep a diesel running. Idling into a tree is the best way to switch a worn diesel off.
AnswerID: 301033
Follow Up By: balko - Monday, Apr 28, 2008 at 20:22
Its only done 26000 ks if its worn after that many ks it deserves to be driven into a tree
FollowupID: 567121
Follow Up By: Member - Olcoolone (S.A) - Tuesday, Apr 29, 2008 at 08:51
At a guess I would say the same thing, check your oil level and see if it going down.
Might be the turbo!
Regards Richard
FollowupID: 567193
Reply By: StormyKnight - Monday, Apr 28, 2008 at 22:19
I thought the days were gone where you could run a Diesel without any electrical power......good to see some still around!
Not exactly related, but you need electrical power to start these engines (starter, glowplug & injection pump lever) & then you need electrical power to stop them (pull injection punp lever to off)...but you don't need electrical power for it to run! Those were the days....
BTW, a TD Prado (1kzte) with engine computer will run at least 150km with a buggered alternator...a petrol Prado only about 5kms!
AnswerID: 301077
Reply By: balko - Tuesday, Apr 29, 2008 at 12:25
Found how to turn it off from motor pull a lever that is attached to a cable. found two wires that look like they should be attached some where near the lever . now just got to work out where they go and there LIVE bloody sparks Cheers
AnswerID: 301143
