Site Search
Section Image
Smokey 4.2 TD Cruiser 80 Series.
Submitted: Friday, May 02, 2008 at 07:06
Hairs
Hi Guys,
Just wondering what would cause this smoke.
I've got a 91 TD GXL 80 series manual cruiser.She's got 286500 k's on her now, goes a treat. But she blows smoke. Has done for a while now. I've noticed when I travel away from the sun late evening. It's whitish in colour. A mate has followed me and said that it's not dark like oil smoke it's rather white and fine not heavy and black. After doing some heavy beach work at high tide in the soft sand the smoke completely disappears. He said it does not smell like oil smoke. When cold it is more noticeable. It does appear to burn oil under normal driving conditions but under heavey slow going it does, not much though. Any thoughts would be appreciated.
Another query I have is when I bought her 3 years ago she came with 31x10.5x15 Duellers on her. She does about 2500rpm at a 100k, is this normal rpm for that speed? I ask cause I find myself wanting to reach for another gear when doing 100kph? I was thinking that the next set of tyres that goes on her would be 33's to lower the revs that she does just a tad.
Do those revs sound about right for doing a 100k?.
I was wondering if the two are related.
Hairs.
The 50,50,90 rule
When you have a 50,50 choice,
90% of the time you'll choose wrong.
Works for me every time :)
Advertisement
ThreadID: 57193 Replies: 7
Views: 714 FollowUps: 11
AnswerID: 301610   Submitted: Friday, May 02, 2008 at 07:12
Hairs replied:
typo,
The bit about burning oil is suppose to read that it does not burn oil under normal conditions.
Sorry.
Reply 1 of 7
AnswerID: 301613   Submitted: Friday, May 02, 2008 at 07:41
Rock Ape replied:
White smoke is unburned fuel, your injectors probably need attention, a set of 33's will lower the revs a little
Reply 2 of 7
FollowupID: 567756   Submitted: Friday, May 02, 2008 at 15:38
Hairs posted:
Hi Rock Ape,
I can't see anywhere in the service history if the previous two owners had touched the injectors.
They have listed everything that has been bought, Fixed or add to it.
So may be a trip to an Injector specialist .
When I first looked at before I bought her she had 33 on. When I went back they had taken them off and put the 31's on. I couldn't get them to put the 33's back on.
No use losing sleep over it.
AnswerID: 301616   Submitted: Friday, May 02, 2008 at 08:08
autosparky replied:
i thought black smoke wsa unburnt fuel
Reply 3 of 7
FollowupID: 567705   Submitted: Friday, May 02, 2008 at 10:32
Mainey (wa) posted:
yes, as seen in big trucks under load
wake behind the Stacer 420 SeaHorse
Click Image to Enlarge
* check-out how SÔLAR PÔWER & ¹² Vølt Batteries will work *
click-> "My Profile"
below
FollowUp 1 of 5
FollowupID: 567726   Submitted: Friday, May 02, 2008 at 12:27
Rock Ape posted:
Both white and black smoke indicate unburnt fuel
FollowUp 2 of 5
FollowupID: 567863   Submitted: Friday, May 02, 2008 at 21:58
autosparky posted:
depends on the quality of the fuel white smoke is indicative of oil as fuel
FollowUp 3 of 5
FollowupID: 567866   Submitted: Friday, May 02, 2008 at 22:08
Member - DOZER posted:
Black smoke denotes too much fuel, or bad timing causing incomplete burn, white smoke denotes not enough air or compression. Check the inlet for estrictions and also the turbo for excess play.
If you are not loosing coolant, and the turbo is boosting well (2000 green light) have the compression chaecked.
Lastly, it is a common fault of these motors to bypass oil back into the inlet. Install a pneumaticr water trap in the line, and empty the oil each fuelup.
b4 you bag me out, walk a mile in my shoes, then your a mile away and have my shoes :)
FollowUp 4 of 5
FollowupID: 567871   Submitted: Friday, May 02, 2008 at 22:20
autosparky posted:
more commonly it means that the rings are on the way out, especially with an older t/d motor
FollowUp 5 of 5
AnswerID: 301617   Submitted: Friday, May 02, 2008 at 08:14
traveller2 replied:
Whitish smoke can often be condensation in the exhaust burning off.
Whitish sweet smelling smoke can also be coolant burning off ie: leaking head gasket or coolant somehow making its way into the combustion chamber, water cooled turbo?.
Reply 4 of 7
FollowupID: 567757   Submitted: Friday, May 02, 2008 at 15:42
Hairs posted:
Hi Traveller2,
I can't be that, 18 months ago the head warped one very hot November day. It had to be machined, spent quiet a few dollars getting that fixed. The level has not dropped at all in that time.
She's a factory TD.
Activities Index
Abseiling 3 Hours Abseiling 3 Hours
Brisbane - QLD
Kangaroo Point, in the heart of Brisbane's CBD, provides the perfect opportunity for you to enjoy an
Quad Bike Adventure Quad Bike Adventure
Central Coast - NSW
Get ready to have the most fun you can have on four wheels as you ride around bush trails and open p
Tiger Moth Scenic Flight - 30 minutes - NSW Tiger Moth Scenic Flight - 30 minutes - NSW
Sydney - NSW
Fly back to the 1940s in a vintage open cockpit bi-plane.
Hang Gliding Tandem at Byron Bay Hang Gliding Tandem at Byron Bay
Far Nth Coast / Byron - NSW
Experience a 30 minute tandem hang glide over Cape Byron.
Book Now - Things To Do
AnswerID: 301638   Submitted: Friday, May 02, 2008 at 09:56
Matt(WA) replied:
Hairs,
I have a 94 TD 80 Series and run 33's(285 75 16's) on 16x8's. At 100km's an hour on the gps I am doing 2400rpm or just under. Whit smoke normally means unburnt fuel. i would have it checked out by a specialist diesel shop. Get them to put it on the Dyno and have a look. Saves you money if you dont need the injectors done. Though if the injectors havent ever been done I would recomend it. Also I can recomend getting the fuel pump timing done and your valves shimmed. Just had my valves shimmed and its a different car. Hope this helps
Matt
Ok I'll go first
Reply 5 of 7
FollowupID: 567760   Submitted: Friday, May 02, 2008 at 15:55
Hairs posted:
Hi Matt,
I'm thinkin' I'll save up and send it to a specialist diesel Grease monkey with a Dyno. As you pionted out its money well spent.
The fuel pump timing could be something as well. I had the top of the pump off a few months back to replace the o' ring in top of the pump. Had a bugger of a time putting that back together. Not good when I have hands the size of dinner plates.
It does not lack power, it goes like the clappers.
I'll look into getting it tested on a dyno.
Thanks for your suggestion
Cheers.
AnswerID: 301651   Submitted: Friday, May 02, 2008 at 10:58
howesy replied:
32's are equivalent to your standard size tyre. And all the reasons mentioned can give you what you describe including turbo seals. If you never ever have to touch your coolant level I wouldn't worry about it too much until it gets worse then take it in to get checked. it will be more easily diagnosed if you let it play out a little longer. Just make sure you never lose water.
Reply 6 of 7
FollowupID: 567763   Submitted: Friday, May 02, 2008 at 16:07
Hairs posted:
Hi Howesy,
I dropped into my local tyre shop and 32's are pretty close to the standard setup for my model. My 31's look a bit small, I'll chase around and see if someone locally could maybe loan/borough a set of 33's for a week to give me some idea what rpm it will do.
I always thought the tyres on her where a little on the small size.
I'm put an engine flush in her next time I do an oil change.
Can't hurt.
Thanks for all the ideas guys, I'll work my way through them and see what it brings.
Cheers.
Hairs.
AnswerID: 301760   Submitted: Friday, May 02, 2008 at 21:20
warbo replied:
white smoke is unburnt fuel,black is soot (burnt) when motor is cool white smoke is present when you work it hard engine block heats up and burns excess fuel (no white smoke) A test you can do when cold is at idle have a mate at rear of car you go and crack an injector one at a time motor will shudder but not stop, if smoke clears, it is that cylender causing you grief. If its been looked after it wont be a bent conrod from water compression (water crossing) but after 285k i would do injecter changeout !
Reply 7 of 7
FollowupID: 568146   Submitted: Monday, May 05, 2008 at 12:27
Hairs posted:
Hi Warbo,
Next weekend when a mate comes over i will give your suggestion try.
Thanks for the tip.
Hairs
FollowUp 1 of 2
FollowupID: 569427   Submitted: Sunday, May 11, 2008 at 20:13
Member - Hairs (Lawrence,NSW) posted:
Hi Warbo,
Gave your suggestion a go and all of them seem the same. No big difference between them.
I'm thinking an injector service is in order, I've replaced the fuel filter, cleaned the K&N air filter and thrown in some Chemtec diesel additive. I asked a mate who would be close by who could help me and there is somebody.there's a bloke in Yamba, I've actually know his younger brother for sometime now. He has a Dyno and is in to diesels. I'll give him a ring and make time to go and see him.
Cheers for all the suggestions guys, Much appreciated.
Thanks.
Hairs
Last seen near the Malara Fire Trail 01 2009 EO Northern NSW/SE QLD Gathering
Jon
Which witch wished which wicked wish?
Don’t Take Life Too Seriously; You Won’t Get Out Alive
FollowUp 2 of 2
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
