Instant Gas Hot Water system
Submitted: Sunday, May 04, 2008 at 09:13
Member - Drew T (Melbourne)
Looking at putting an instant LPG gas hw system in a caravan for hw to the sink and for the occassional shower. Caravan is typically parked on a bush block with no 240v (although the van does have a substantial solar/bty setup). Prefer a system that is fully automatic & no external power requirements as different people use the van & I want to keep it as simple as possible. 2 systems i have found are:
1. 6 l/min unit from www.ausj.com.au which uses D cells to automatically light the gas. approx $350
2. Bosch 10H (same as Bosch WR 250-1 ?) unit which is 10 l/min & uses 'hydropower' (no elec required) to light the gas. approx $650
Anyone used either unit or know of similar systems that might meet my needs?
Reply By: Dunaruna - Sunday, May 04, 2008 at 10:09
I have the 13H (same design as the 10 just a bit bigger). Have used it for 5 years now, no problems. The hydro start is great.
301951
Reply By: Member - kevin Y (SA) - Sunday, May 04, 2008 at 11:26
lived in c/p for a few years -----installed a bosch one which was battery start, battery lasted all the time i was there- 3 yrs ---bat is only used for ignition --so wouldlook hard at the cheaper one as
well
301965
Reply By: Member - peter C (VIC) - Sunday, May 04, 2008 at 11:33
hillbilly
camping gear have an lpg system with auto ignition which looks pretty good to me.you can call them on 0407540005 peter
301967
Reply By: David - Sunday, May 04, 2008 at 11:55
Hi Drew T
Please have a look on ebay for Item number: 220231007673. This is a gas hot
water system that I have and find it really good. I use it for filling my spa and it is a great unit. It runs on
water pressure and has 2 d cell batteries for ignition only. Please have a look at the item and hope it helps you.
David
301969
Follow Up By: Peter 2 - Sunday, May 04, 2008 at 19:51
We've got one of these too, installed in a shed to supply a shower and tub/sink.
It works really
well using either mains pressure or pressure from a12v pump, we've had it hooked up both ways, great hot
water for a shower.
I've mounted it inside on the wall and vented the flue back out side.
The gas bottle sits outside and I've run the hose through the wall.
Great unit and I highly recommend them.
As long as you vent the flue back outside and don't mount the unit on a combustible surface/wall you shouldn't have any problems in a stationary van.
568090
Follow Up By: Member - Drew T (Melbourne) - Sunday, May 04, 2008 at 20:35
thanks .. this is the same as the 6 l/min unit i refewrred to but its interesting to see their is a new 10 l/min model
thanks again
568099
Follow Up By: Member - Drew T (Melbourne) - Monday, May 05, 2008 at 17:54
jeez they are 3 pretty bad reviews!
568211
Reply By: Paul Grabonski. Vic - Sunday, May 04, 2008 at 15:16
To comply with the gas installation regulations you would need to mount the instantaneous hot
water system externally. There is no instantaneous hot
water system approved for internal caravan use.
301995
Follow Up By: Paul Grabonski. Vic - Sunday, May 04, 2008 at 15:21
The AusJ unit has no AGA Aus approval. Means they can sell the unit and you are not allowed to use it. Yes the laws are an ass at times.
Personally would buy the 10L unit as 6L is slow. 6L would be maximum with maximum pressure. In reality possibly 4 to 5L in most installations.
568051
Follow Up By: Nomadic Navara - Sunday, May 04, 2008 at 16:27
To comply with the Australian rules the combustion air must be drawn from the outside air and flued to the outside air. As yey, no one makes a unit to comply.
Hanging one on the outside should be OK - just don't install it inside.
568055
