100 series idle up button
Submitted: Monday, May 05, 2008 at 07:02
i lean
Hi guys
Is there any way to set up the idle button to get the revs you want for charging batteries or to get shower
water at the right temp.
I know I can always put something on the throtle cable but was just woundering if there was another way.
Reply By: lotz - Monday, May 05, 2008 at 10:49
G'day i lean,
To bring revs up at idle, have motor idling, (neutral, handbrake on) turn on cruise control, press set, keep pressing increase to bring revs up........should do the trick, if no cruise control, 850rpm measured stick between the throttle and the dash does the trick.
Make sure alterator activates.
302106
Follow Up By: i lean - Monday, May 05, 2008 at 14:08
Looks like Ill have to use a stick my cruise control wont do that
568161
Follow Up By: TD100 - Monday, May 05, 2008 at 19:23
the cruise wont operate with the car sitting still,it needs to be doing 40k or so before it will work.the fast idle only works when the car is cold,it turns itself off when the temp rises slightly.so no joy with it working when its warm or sitting still!
568234
Follow Up By: lotz - Monday, May 05, 2008 at 19:34
G'day All
Yep, lesson learned, I am used to Cat, GM, Merc, Scania etc, we use cruise control to increase revs to build up air when hooking up trailers etc. Worth a try, All the best.
Lotzi
568238
Follow Up By: Member - JohnR (Vic)&Kath - Monday, May 05, 2008 at 20:49
seems like lotz to learn about L'cruiser cruise control which cancels memory of settings at a speed below 40kph. TD100 has it right, what a bugga. Good to re-program it.
568265
Follow Up By: lotz - Monday, May 05, 2008 at 21:01
Lol, yep always learning lotz from this sight, only offered a suggestion, havn't had experience with the cruiser cruise control.
568268
Reply By: Member No 1- Tuesday, May 06, 2008 at 08:16
turn aircon on....giving the motor some load to get it warm...it also increases revs...but havent noticed by how much
302270
