Whistling Troopy
Submitted: Thursday, May 08, 2008 at 12:05
Member - Agroe (WA)
I have a 2004 troopy with 1hz non turbo eng. whistles like a turbo under part throtlle up to full throttle . Worse under load. Appears to get worse when warmed up. Appears to be coming from exhaust pipe. Also quite loud under vehicle as
well. Has anybody had similar problem. Troopy has done 90,000km. thanks in advance Agroe
Reply By: Member - Footloose - Thursday, May 08, 2008 at 12:58
What tune's it whistling ? :))
I had a problem with a hole in the manifold once that produced similar results.
302675
Follow Up By: Stu & "Bob" - Thursday, May 08, 2008 at 16:16
Teach it the words...:))
Sorry, couldn't help it. :)
568818
Reply By: Stu & "Bob" - Thursday, May 08, 2008 at 16:15
Is it coming from the muffler?
Maybe there is heaps of soot in the muffler causing a restriction, hence the whistle?
Just a thought
302706
Reply By: Member - John and Val W (ACT) - Thursday, May 08, 2008 at 16:47
Probably doesn't apply to your much younger diesel Troopy, but our older petrol one had a habit of pressuring (don't know if negative or positive pressure) its fuel tanks, resulting in whistling fuel caps. Might be worth checking out as it seems the faster you draw fuel from the tanks the louder your whistle - easy to check by just removing/loosening the cap/s.
HTH
| J and V
- Albert Einstein
302715
Reply By: Member - David P (VIC) - Thursday, May 08, 2008 at 16:50
What sort of electrical load at the time....alternator?...silverback
302717
Reply By: RovingOz (QLD) - Thursday, May 08, 2008 at 17:45
When we installed the reversing camera we got the same noise - couldn't work it our for a while - it was coming from the speaker in the LCD screen.
302730
Reply By: westozal - Thursday, May 08, 2008 at 18:24
Hi Agroe,
My old 80 series pet4.5 used to whistle as a few revs came on...was the exhaust mainly the muffler. Got a new system, noise never returned.
Alan.
302740
Reply By: Member - steve H (QLD) - Thursday, May 08, 2008 at 19:20
My son's mate has a non turbo troopy ute and his whistle comes from a small air leak in the
snorkel
Steve
302751
Reply By: Member - Agroe (WA) - Friday, May 09, 2008 at 01:38
thanks for the replies it soundslike the exhaust. but reluctant to replace on off chance. i thought about
snorkel but the noise is defitnitly at the rear. Would a egr valve do it. thanks Agroe
302809
