Hand Winch Info
Submitted: Friday, Nov 30, 2001 at 01:00
Rob
Does anyone have any info about an "anchor" brand 4wd type winch. It looks very similar to a Tirfir and weighs the same so it is solid enough in construction. Uses 11mm wire cable. Was made by Anchor Engineering Co. Ltd. in
Richmond Victoria and has Dept of Labour & Industry (Vic) certification.
I'm trying to find out if anyone supplies spare parts like the shear pin and a handle.
Rob
Reply By: tim - Sunday, Dec 02, 2001 at 01:00
rob see this months edition of 4wd monthly for tests on hand
winches
1519
Follow Up By: Rob - Monday, Dec 03, 2001 at 01:00
yes...seen that Tim. Although they are all latest models and this one looks to be at least 10 years old.
478
Reply By: Rod - Monday, Dec 03, 2001 at 01:00
Suggestion, the shear pin is probably nonferrous metal, so all you need is some rod of the same diametre (probably 6mm) and cut your own.
1521
Follow Up By: Rod - Monday, Dec 03, 2001 at 01:00
Nonferros being Bronze.
477
Reply By: porl - Wednesday, Dec 05, 2001 at 01:00
Don't know the winch you are talking about but know the design. All i have to add is that in talking to a chain and winch guy who makes them (for the engineering industry) and sells them and lectures 4WD clubs on safe uses of hand
winches - he said be wary of the Tirfor copies that are made out of aluminium or alloy composites as they have a tendency to warp and break when used to pull in anything other than a dead straight line.
1528
Follow Up By: Rod - Wednesday, Dec 05, 2001 at 01:00
Please clarify 'pull in anything other than a dead straight line.'? As once the strain is taken up everything lines up to be in a dead straight line!!
484
Reply By: Robert - Friday, Dec 07, 2001 at 01:00
Hi Rob,
I recently purchased from a guy the same brand of winch as you mention it's actually called a Super Til winch that was made by a company called Anchor Engineering I believe which no longer exists?, however there is a company in New Zealand who sells a wire rope winch referred to as " Super Til " , I have sent an email to them to enquire whether this brand is in any way related to the one made by Anchor Engineering, will let you know if I get any info back from them.
P.S Yes I agree with you on their construction which is why I didn't hesitate to buy
mine - I figured being older and made in Australia (Not a cheap import) was peace of mind in regard to quality. and I certainly didn't want to spend around $400 secondhand to $700 new on a Tirfor which wouldn't be any better.
Cheers Robert
1547
Follow Up By: Robert - Friday, Dec 07, 2001 at 01:00
Rob,
Apparently Super Til
winches are still being manufactured in Japan by a company
called Honko Seisakujyo Co Ltd.
Pacific Hoists ( pacific-hoists@xtra.co.nz ) represents them in New Zealand and carry spare parts for the 3
models, the person I communicated with was Glen Hall New Zealand Manager who was quite helpful.
Apparently Anchor Engineering still exists as PWB AnchorEngineering but sells a Chinese made unit called Tugger.
489
Follow Up By: Rob - Tuesday, Dec 18, 2001 at 01:00
Thanks for the in-depth info Robert. I haven't had a chance to check back for a while but I will get in contact with that person and find out what I can.
Rob
524
