plenty highway and cattle water pass
Submitted: Saturday, May 10, 2008 at 19:32
motor_head
hey guy's, what tyre pressure would you recommend for the
plenty highway, i will be travelling through in late june and would have opted for 28psi but recently read on another site the locals choose high pressure to keep the side walls tucked in, i run cooper s/t, also i will be towing a coromal 10ft offroad camper and wondering if i will have any drama's with it on the cattle
water pass road. CHEERS.
Reply By: Hairy (NT) - Saturday, May 10, 2008 at 19:49
Gday
I'd run 35-40 psi on the
Plenty highway , only because Im not into farting around with tyre pressures other than dropping them in the sand.
Cattlewater pass is "not recomended for trailers" but you shouldnt have any trouble.
Hairy
303094
Reply By: Kiwi & "Mahindra" - Saturday, May 10, 2008 at 21:53
bucky towed his trak sahk through there just taking it easy no worries...even had a subie forrester go throug with us and she was fine....as for tyre pressure...same as the rest of the roads out there.....its only a short amount of km along there into altunga but boy dies it take for ever....a good 3 -4 hrs from memory with 3 cars....
hope this helps....our tyre pressure was about 30 - 35 i think....!
303132
Follow Up By: Kiwi & "Mahindra" - Saturday, May 10, 2008 at 21:54
sorry about the pseling....had a few wines...
Laura
569284
Follow Up By: Member - Bucky (VIC) - Sunday, May 11, 2008 at 17:16
Laura..
I run 25 psi along the Plenty, softens up the going, and lets the tyre mould around gibber, and other shyte you will be driving over..
No Wuckers
Cattlewater Pass is an easy run, only put it into 4x4 mode once..
Same tyre pressures,(25psi), till I hit the bitumen, on our run into Alice..
Cheers Bucky
569384
Follow Up By: motor_head - Sunday, May 11, 2008 at 19:11
Thanks Bucky, i hear some of that gibber is quite sharp.
569415
Reply By: mattie - Sunday, May 11, 2008 at 10:01
I would keep below 40psi the lower the pressure the more inclination of the tire moulding around rocks when travelling over them rather than a tight tire having to bump up over
the rock or
the rock piercing through the tire instead(when fully loaded and ct on i have never put more than 35psi)i don't know if i explained it very
well??
Mattie
303198
Reply By: Member - John and Val W (ACT) - Sunday, May 11, 2008 at 10:15
Cattlewater pass is OK if going south from the
Plenty Highway. If going north from Arltunga there is a short steep section with some big rocks that requires care. We had to snatch a smallish SUV towing a CT off there last year.
Val.
| J and V
- Albert Einstein
303200
Follow Up By: motor_head - Sunday, May 11, 2008 at 19:08
thanks val, yes i will be heading south
569414
Reply By: motor_head - Sunday, May 11, 2008 at 19:05
ok thanks everyone, cattle
water pass sounds easy enough with the camper, i was more worried about the width, its at least 300mm wider than the prado, think i'll run about 30psi on the tyres although i hear the plenty is alot better these day's.
303287
Reply By: balko - Saturday, Jun 07, 2008 at 19:31
Just did cattlewater yesterday and on the northen end near the plenty hwy there is a few deep wash out ruts that could topple your van if you slip into one so try to go with some one just in case. But there is plenty of width for the van just a few odd sticks that you can remove by hand. Cheers Tony
308393
Follow Up By: motor_head - Sunday, Jun 08, 2008 at 12:47
Thanks balko, very helpful, yes i will have another vehicle travelling with us.
574473
