Franz Filter
Submitted: Saturday, May 10, 2008 at 22:45
ThreadID: 57476 Views:2680 Replies:2 FollowUps:1
Hi, Anyone running Franz oil filter system? What do you think of them and how far have you extended your oil change interval? Cheers. Snake and Josie
Reply By: Member - SNAKE QLD - Saturday, May 10, 2008 at 23:17
Should read Frantz.Snake
AnswerID: 303147
Reply By: Member - David P (VIC) - Sunday, May 11, 2008 at 13:07
The question I would ask is does it filter out the additive package the lubricant engineers put in?.....silverback
AnswerID: 303225
Follow Up By: STAN - Sunday, May 11, 2008 at 21:31
I have a Frantz filter on my Pajero 2.8 ITD . Have extended the oil changes from 5000 to 30000k with regular oil analysis from William Adams in Melb. No doubt this could be extended further and I will probably do so. The oil adatives get replentished every 5000k with the Frantz filter change [1 litre oil + a toilet roll]. The particulate count is the same at 30000 as is at 5000. I have read where some opperaters have extended out to 100000k, but I would not recomend that without proper oil testing along the way. Hope this helps Stan
FollowupID: 569444
