Any ideas how to mount a laptop in vehicle
Submitted: Sunday, May 11, 2008 at 21:08
REV'S
I have a 70 series landcruiser cab chassis, and would be interested in any ideas of how to secure a laptop in front of the passenger so that the computer may be used while travelling. Any idea would be great and photos if possible would be much appreciated
Thanks for any ideas.
Cheers Rev's
Reply By: Member - Warfer (VIC) - Sunday, May 11, 2008 at 21:15
*Any ideas how to mount a laptop in vehicle*
I don't know about the laptop but gee i have troubles just trying to mount the missus in vehicle !
303328
Follow Up By: Willem - Sunday, May 11, 2008 at 21:23
Good on ya Warfer!! What its like to be
young.....hahahahaha
569442
Follow Up By: Wetty - Sunday, May 11, 2008 at 21:37
I was gonna say from behind. . . . . but that'd be rude wouldn't it?
569445
Reply By: Member - Bentaxle - Sunday, May 11, 2008 at 22:09
I use a RAM Mount from GPSOZ cost around $350 but there are no hole to drill just use existing bolts in vehicle Its very satable with negligable vibration. Have photos somewhere will try and locate and post for you.
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
303345
Follow Up By: REV'S - Sunday, May 11, 2008 at 23:03
Hi Bentaxle,
I have looked up the site and found it to be very helpful. I will follow this up, just what I need.
Thanks for your reply.
Rev's
569468
Follow Up By: Richard W (NSW) - Monday, May 12, 2008 at 06:32
Also use the RAM mount. Pricey but does the job.
569479
Follow Up By: Member - Bentaxle - Monday, May 12, 2008 at 21:15
What I found was great is that you can set up youre own configuration and positioning and height of the RAM base to suit your own requirements
569604
Reply By: Member - Phil G (SA) - Sunday, May 11, 2008 at 22:41
This one belonged to a friend - it just sat there - hooked into the bar - very simple.
Mine folds away in a pocket and output goes to a 7" dash screen.
Image Could Not Be Found
303357
Follow Up By: REV'S - Sunday, May 11, 2008 at 23:07
Thanks for the pic. Great idea, only I,m looking for one that sits lower. Thanks all the same
Cheers Rev's
569471
Reply By: Member - Phil G (SA) - Monday, May 12, 2008 at 06:57
That photo was from 8 years ago. Its not where I'd mount it - my wife wouldn't have a bar of it! She's not a keen navigator, which is one reason I like the remote screen. I have photos in my profile.
You'd need a pretty small laptop, and preferably a tabletPC to squeeze it into the cab of a 70series.
303381
Reply By: Vivid Adventures - Monday, May 12, 2008 at 08:19
Here's two ideas:
1. the way I used to have it - on a home made stand - made out of the post of a broken adjustable office chair, and some polypropylene offcuts with velcro to hold it on (oh, I made up a bracket that sits under the inside front bolt of the passenger
seat
2. an in-dash pop-out computer TFT monitor that connects to the laptop that stays in a bag in the rear passenger footwell. Unfortunately the design of the 100 series dash makes it hard to install easily...
Andrew.
303392
Reply By: John L - Monday, May 12, 2008 at 10:02
This is how we solved the problem
Laptop Stand
Hope it helps
303406
Reply By: Member - Warfer (VIC) - Monday, May 12, 2008 at 11:24
I know they serve a purpose,but gee there all bloody ugly looking things (stands)..
Richards isn't bad but as he said it wasn't cheap..
303416
Reply By: ben_gv3 - Monday, May 12, 2008 at 12:20
I'm also thinking about mounting a lappie in my 96 Troopy but I am hesitant to as it's a significant safety
hazard in an accident. Wouldn't want the passenger getting too intimate with the lappie on a suddent stop.
303421
Follow Up By: Member - bushfix - Monday, May 12, 2008 at 12:28
jealous
569523
Reply By: The Geriatric Gypsies - Monday, May 12, 2008 at 18:26
goodday people
a question for those that hang the lappy on the back of a
seat or whatever How do you go with the fans and dissapating of the heat produced
steve
303459
Follow Up By: Vivid Adventures - Monday, May 12, 2008 at 22:55
Trick is to keep it out of the sun... the old Tosh laptop I have (looks like PhilG has a very similar one) has a fan at the back left, which I keep oriented to the top and it works fine, even in the laptop bag it is in - although I leave it unzipped in that corner.
569625
Follow Up By: Member - Phil G (SA) - Wednesday, May 14, 2008 at 11:38
Yep, theres a fan - I think my Tosh only turns on when it gets hot. Also, when the laptop is closed, the screen is off, so it generates no heat.
Mine sits in a pocket with foam and carpet padding.
569870
Reply By: REV'S - Monday, May 12, 2008 at 22:04
thanks to everyone who replied, has given me plenty to think about. some great ideas.
Cheers Rev's
303502
Reply By: VH-GU4 - Tuesday, May 13, 2008 at 10:08
Mount the lap top behind the
seat and then mount a 7 or 8 inch touch screen in the front some where. Its a lot safer to have the lap top behind the
seat. And yes a 7 inch screen is big enough to see moving maps because you just zoom in on the screen.
303537
Reply By: Member - Graham H (QLD) - Tuesday, May 13, 2008 at 10:39
If you decide to go with the Rammount option
I have the top tray that holds the laptop spare at the moment.
Have only used it on 1 tarmac trip and decided to get a smaller screen.
Have mounted that differently and dont use the tray.
Its RRP is over $100 so make a decent offer, any one
PIcs below of setup .
Tray is as shown in previous replies
303545
Reply By: Member - Mick O (VIC) - Friday, May 16, 2008 at 20:19
If you check out my rig page you'll see a laptop mount I had made by Brown Davis in Bayswater (Melb). I use a ram laptop table on top. Very robust.
Cheers.
Mick
304211
Reply By: RnR - Saturday, May 17, 2008 at 11:37
Hello,
I've read this thread with interest and also been looking at associated threads on this subject. Can anyone recommend a good in dash TFT screen I can connect to my laptop for moving map?
RnR
304310
Reply By: Member - Craig M (QLD) - Sunday, May 18, 2008 at 11:18
Howdy All
As usual, I summons the Gods from Ebay
Have a look at this item
310050307961
Might do the trick with a bit of modification maybeImage Could Not Be Found
Craig
304457
