RB30 Nissan Backfire problem
Submitted: Sunday, May 11, 2008 at 22:18
Kev C
Hi All
My '93 Patrol was always a good bus, but in the last few months has given me a lot of trouble. It was missing badly & backfiring through the carbi. I have got rid of the miss but it still backfires.
In recent months I have done the following:
Replaced the head
new plugs
new leads
new rotor
new dizzie cap
extractors
tried various timing settings.
run carbi & injector cleaner through fuel
run motor cleaner through oil
removed heater
grid from carbi
checked pcv OK
replaced all small vacuum hoses
dimantled & inspected LPG mixer
compression test OK
It backfires through the Carbi at irregular intervals on gas or petrol. It does run better on petrol.
After replacing the head this weekend it ran very
well on the test drive, it even idled exceptionally
well, which it hasn't done for some time. It used to have a miss at idle. I took it off road to go fishing & found that the backfiring through the carbi is still as bad as ever.
Does anyone have any ideas?
Kev
Reply By: Member - David P (VIC) - Sunday, May 11, 2008 at 22:23
I would check the exhaust valve ajustment, not sure , are they shim?.....silverback
303348
Follow Up By: Member - David P (VIC) - Sunday, May 11, 2008 at 22:27
and is it more pronounced when hot?....silverback
569461
Follow Up By: Kev C - Sunday, May 11, 2008 at 22:36
It has non adjustable lifters. I don't get any tappet noise, so I think they are OK. I have just replaced the head because I thought that the exhaust valves may have been recessed by usuing LPG for 15 years.
The backfire happens hot or cold, no discernable difference.
Kev
569462
Follow Up By: Member - David P (VIC) - Monday, May 12, 2008 at 19:14
I would check all valve clearances incl inlet....cheers....silverback
569575
Follow Up By: Kev C - Tuesday, May 13, 2008 at 17:22
Hi David
The valve clearances are not adjustable on the RB30. Are you suggesting a worn cam? If so would I have any other indication of a worn cam?
Kev
569751
Reply By: TD100 - Monday, May 12, 2008 at 20:29
My mates VL did the same thing years ago,we had pulled all our hair out trying to sort this thing out,in the end it was the dizzy worn out.had too much end and side play,rebuilt it and all was good.cheers Paul
303476
Follow Up By: Kev C - Tuesday, May 13, 2008 at 17:25
Hi TD100
I had though about the dizzi as
well. I checked it for play whilst it was out. It was as solid as a rock.
Kev
569752
Reply By: landed eagle - Monday, May 12, 2008 at 20:53
Had a head replaced on an Econovan years ago and it did the same thing. Checked everything as you have and found that the timing chain was one tooth out after it had been "professionally" done.
303483
Follow Up By: Kev C - Tuesday, May 13, 2008 at 17:37
Hi Eagle
I had a bit of a panic attack when I reassembled the head. When I reattached the cam pully the belt was 2 teeth out from the marks that I had put on it. It took me a while to figure out that it had slipped 2 teeth on the crank & was OK. I can see how easy it could be to remain 1 tooth out.
I did check the timing after the head job & it was OK. The backfiring was happening before I replaced the head. I had hoped that it would have fixed the problem.
regards
Kev
569754
Reply By: nowimnumberone - Tuesday, May 13, 2008 at 19:17
have you had the carby off and recoed?
303643
Follow Up By: Kev C - Wednesday, May 14, 2008 at 01:01
No I haven't done the carbi yet. It is starting to look like the next option to me. I will be buying a carbi kit as soon as I can afford one.
569824
