how to identify Toyota 2H diesel engine?
Submitted: Monday, May 12, 2008 at 00:55
Werner Gutierrez
Howdy,
I have Landcruiser with a replacement motor. To prepare for a rebuilding job, I need to determine if I have an early or late model 2H.
Engines from 8/80-3/82 use a piston with a 27mm pin diameter,
4/82-11/84 has a 29mm pin diameter.
So there are substantial differences when it comes to ordering parts.
Any suggestions on how to proceed without taking the motor out?
The block has number 68010 stamped, the serial No. is 1020188.
thanks
Werner
Reply By: Member - Tour Boy Springsure- Monday, May 12, 2008 at 06:42
Take the engine # to toyota and they should be able to help.
There is an early and late head too.
303380
Reply By: Member - DOZER- Monday, May 12, 2008 at 12:53
84 to 90 have no slieves /parent
bore too. I suppose you have thought about buying a good runner from a later cruiser? say a 12ht
303425
Follow Up By: Member - res.q.guy (VIC) - Monday, May 12, 2008 at 15:13
Hi Andrew
I have a Dyna Twin cab truck that has a 2H enging (not going), and wondering if to reco the motor or buy a secondhand one.
Do you know if a 12ht replaces a 2h ? or do you have to alter engine mounts and get adaptors etc ?
Neil
569539
Reply By: Member - Davoe (Yalgoo) - Monday, May 12, 2008 at 15:25
belts and all are different and wahat about rom 84-90?
303443
Reply By: Member - Pesty (SA) - Monday, May 12, 2008 at 18:31
I think taking the ID to a toyota spares place would be the best, also the early ones had sleeves
A MM to Outandabout David on this
forum may be able to help you.
Chee4rs Pesty
303460
Reply By: Werner Gutierrez - Tuesday, May 13, 2008 at 05:55
Hi everybody,
thanks for replies.
I am still waiting for answers (Argentina and Switzerland).....
thanks for pointing this out, I did not know
To buy used stuff in Argentina is not advisable, also not sure if I could even find one. Also learnt that better stick with things one finally got to know and had to tweak anyway.
I took out the original F2 from this FJ45 LV-KCW 1980 and went through a bit of adapting to place this 2H, thus prefer to rebuilt this one.
Frankly, the 2H work wonderful, what is better using a 12ht?
belts: I suppose you refer to outside belts to alternator etc?
rom: goes beyond my English
By the way, went to “Abbreviations” to see if ROM is in there, no.
But I did find WTF, which I use for my email address and signature, ‘cause these are my initials.
Well, I might change this habit.....
best,
Werner
303517
