Synthetic Manual Gearbox Oil ?
Submitted: Wednesday, May 14, 2008 at 12:29
Member - Glenn D (NSW)
Hows it going guys,
I have noticed my gear changes getting a bit rougher. At first I thought it was only when cold , but its doing it all the time.
I have only done 40k since I changed the oil in my gearbox with the mineral oil recommended in the manual, I dont think thats very long ?
Is anyone using anything other than the standard oil with any success in a GU ?
Thanks,
Glenn.
Reply By: Robin Miller - Wednesday, May 14, 2008 at 12:42
Always used the same 1 synthetic gearbox oils in diffs and gearbox, and it does work
well , use same grade in each , think its shc 85w or similar. Note - Have no rear lsd now , but they have a grade for lsds as
303731
Follow Up By: Member - Glenn D (NSW) - Saturday, May 17, 2008 at 12:50
Thanks Robin , going to give the Valveoline semi synth a go .
Glenn.
570403
Reply By: Mr Pointyhead - Wednesday, May 14, 2008 at 14:36
People I know have has good success with redline synthetic gearbox oil. See
Redline home page
(No direct affiliation but they do sponsor a cousins race car)
303752
Follow Up By: Member - Glenn D (NSW) - Saturday, May 17, 2008 at 12:44
Couldnt find anywhere to have alook locally ,
Thanks anyway,
Glenn.
570398
Reply By: Member - Barney Rubble - Wednesday, May 14, 2008 at 19:55
Gday glen check out valvoline duragear not to sure of the ratio but has fixed a couple of harsh gear change faults at work
but not only that gearbox & diff oils should be changed every 40 thou anyway if not sooner cheers
barn
303801
Follow Up By: Member - Glenn D (NSW) - Saturday, May 17, 2008 at 12:48
Hey Barney,
Was able to get this locally so will give it a go ,
My manual says gearbox oil very 100k , but I guess you can tell when it needs it.
Glenn.
570402
Reply By: bob&loz - Wednesday, May 14, 2008 at 22:30
Glenn
Use the Castrol syntrax 75-90 It made my 2001 GU feel like a car and I put it in the new GU at 1000k, smooth as
Ps
when I drained the oil on the new GU at 1000k the amount of metal on the magnet was the same as the old GU was when I changed it for the first time at 50,000k
303845
Follow Up By: Member - Glenn D (NSW) - Saturday, May 17, 2008 at 12:46
Hi Bob ,
I could only get this in 1 lt containers at $29 a bit out of my league at the moment ( putting money into a camper trailer )
Glenn.
570400
