Dtronic on 3lt Navara
Submitted: Wednesday, May 14, 2008 at 20:36
ThreadID: 57610 Views:3071 Replies:3 FollowUps:2
G'day, I had a Dtronic fitted to my 3lt 2005 Navara yetserday and I must say I'm not overly impressed with the extra power it is meant to give. Am I asking too much, I can hardly feel any better get up and go. The bloke at ARB said when towing and when going up hills I will notice the difference. Has anyone else had the dtronic fitted to their Navara?
Chris
Reply By: Member - Matthew C - Wednesday, May 14, 2008 at 20:55
If its a D-tronic what level is it set on????
You should notice a reasonable result,any dynos before and after.???
Matt
AnswerID: 303818
Follow Up By: Ross H (QLD) - Thursday, May 15, 2008 at 09:23
Yep agree with Matthew
I have a dp chip in mine 2002 and it goes like a rocket, if you have had the exhaust done you need to let them know as the will adjust the chip to suit (ie programing) on 5 mine comes in at about 1200rpm or lower, at 60kmh in 4th gear the turbo is singing.
Best money I have spent just wish I had done it sooner.
Regards ross
FollowupID: 569993
Follow Up By: Member - Graham H (QLD) - Thursday, May 15, 2008 at 17:33
A Dtronic is only adjustable with a laptop or at least mine is and its a new one. A DP Chip has a dial on it
FollowupID: 570052
Reply By: Robin Miller - Wednesday, May 14, 2008 at 21:40
Have 3 friends all with 3lt Navara's , 2 of them new.
All three have had turbo problems.
The latest a 2005, will be having its turbo replaced next week , it has done 70,000km of which 50,000 has been with Dtronic.
The Dtronic certainly gave noticeable boost , and the suppliers do not think it caused the Turbo bearings to go noisy and it loose boost.
Wouldn't be so sure myself.
AnswerID: 303829
Reply By: Chris85 - Thursday, May 15, 2008 at 18:58
I have a stock standard ST-r Navara. The chip is only programmable by laptop but it still should show some significant improvement first off. I don't believe it will affect the turbo because a mate had issues with his turbo and didn't have the dtronic. I haven't had it dyno-ed that might be the next step.
AnswerID: 303979
