Mounting Glind in 78 ?
Submitted: Wednesday, May 14, 2008 at 21:35
ThreadID: 57611 Views:2306 Replies:7 FollowUps:1
G'day folks, hoping for a bit of advice here... I am in the process of fitting a glind to my 78 Troopy, and things are getting pretty tight under the bonnet! Does anyone have any recommendations as to where they fitted the heat exchanger - Ta in advance!
Gil
Reply By: redfive - Wednesday, May 14, 2008 at 22:00
Hi Gil
Is it a 1hz or t/d ???
Glenn
AnswerID: 303836
Follow Up By: gilghana - Friday, May 16, 2008 at 22:04
thanks for reply Glenn - it is a turbo'd 1HZ... Should have mentioned that!
Gil
FollowupID: 570308
Reply By: Crackles - Wednesday, May 14, 2008 at 22:45
There is normally enough space to bolt it horizontal to the firewall above the engine using the 2 existing bolts & this allows an easy connection to the heater hoses being so close.
Water pump is best mounted as low as possible like inside the bull bar to help with suction out of creeks etc.
Cheers Craig........
AnswerID: 303850
Reply By: Member - Dick (Int) - Thursday, May 15, 2008 at 00:03
On my Turbo Diesel Troopy, there is no space under the bonnet to easily attach it so we have in on the inside of the Chassis just about under the driver.
Dick
AnswerID: 303862
Reply By: Member - Leigh (Vic) - Thursday, May 15, 2008 at 08:57
I wrestled over where to fit mine and are pretty happy with the result. Happy for you to have a look if you are in Melb.
Basically it is mounted in the front LHS behind the headlight running vertical. This gave good hose access to the heater pipes and also enabled the pump to be mounted off the inner guard just beside the heat exchanger. The inlet is located just below and in front of the LHS guard and the outlet is straight off the heat exchanger to the shower head. Hope this helps. Cheers
AnswerID: 303881
Reply By: Wayne (NSW) - Thursday, May 15, 2008 at 17:12
Gil,
I have done the same as Leigh. I made up a bracket and mounted the hear exchange vertical behind the passenger head light.
I have the pump on the end of a long hose. The pump goes to the river and pumps the water to the vehicle.
Wayne
AnswerID: 303959
Reply By: gilghana - Friday, May 16, 2008 at 22:07
Many thanks one and all for your replies. Space behind pax headlight already has a compressor so will give the bulkhead idea a go over the weekend!
Gil
AnswerID: 304233
Reply By: redfive - Friday, May 16, 2008 at 23:07
Gil
Give me your email address and ill email you some pics of my setup
Glenn
AnswerID: 304249
