Okay, I'll admit I have a Prado !
Submitted: Friday, May 16, 2008 at 09:36
ThreadID: 57655 Views:4903 Replies:12 FollowUps:23
I currently have a Prado V6 2006 Model, would you suggest I take it around Oz, or would you trade it on a LC100 T/D ?
I'll loose heaps of money trading it.
Do you think a Prado V6 is a decent vehicle to do the lap in ?
I've had it since new and know the vehicle, I've had it off road and I must say I've had a LC100 before, and the prado was more confident than the heavy land cruiser !
I'm not intending to go to any real out out out back places as I'll have my kids with me, I'll normally be on made roads.
Reply By: John R (SA) - Friday, May 16, 2008 at 09:45
I don't understand why you're asking this question.
Quite frankly, there's nothing inherintly wrong with either of those vehicles, and I can't see anything that the LC would let you do that the Prado won't.
I'm sure there are issues such as running costs, carrying your gear and so forth, but it's not as if you're comparing a 1972 landrover with a modern vehicle!
I see no reason to change, based on the info you give.
AnswerID: 304096
Quite frankly, there's nothing inherintly wrong with either of those vehicles, and I can't see anything that the LC would let you do anything that the Prado won't.
AnswerID: 304097
Reply By: Robin Miller - Friday, May 16, 2008 at 09:51
Well Big Marty , I'm not Prado's greatest fan because they
roll more easily than some others and their a bit soft but
have two friends with them ( 1 petrol 1 diesel) who frequently take them very outback including into aboriginals areas where most of us are not supposed to go and the cars have proved to be very effective and reliable long distance tourers with the inbuilt range to get there and get back.
AnswerID: 304098
Follow Up By: Big Marty - Friday, May 16, 2008 at 10:47
Thanks for the help and feedback.
FollowupID: 570170
Follow Up By: Shaker - Friday, May 16, 2008 at 11:01
Sorry, but I dispute your description of Prados as being 'soft', they may need a slight lift, but most stock 4x4s do.
FollowupID: 570174
Follow Up By: Robin Miller - Friday, May 16, 2008 at 11:49
Hi Shaker
I think you will many references to Prado's soft underbelly and various weak panels underneath.
Lifting is a problem with Prado's , being already in the higher risk catergory for tipovers raising the Centre of gravity is not a good idea without increasing the track width.
Because of fouling of the guards its hard to increase track width.
Their are a number of strengthing bits you can do to them and I would go down this path and keep their height at least standard.
In this particular case there is not much off road being considered so marginally lower profile AT tyres on offset rims would be my reccomendation.
FollowupID: 570184
Follow Up By: Member - Olcoolone (S.A) - Friday, May 16, 2008 at 12:54
Robin is there anything that hasn't got a Nissan patrol badge on it that you do like?
Where did you get the information on Prado's being unsafe.
FollowupID: 570202
Follow Up By: Robin Miller - Friday, May 16, 2008 at 13:33
Hi (Think its Richard ) (Olcoolone)
I don't like getting into feelings very much , these things are simply engineering issues to me and going into things with open eyes is most important.
I don't think I have used term "Unsafe" at least not in this post.
In another post somewhere I think I said that current Prado d4d is top of my list for a long range touring Wagon.
Its simply a fact that on Tilt Table tests the early Prado's were well down the list with later versions getting a little better.
Racv was amongst one of those publizing these figures, but if
you wish to look further you will note that on some cruiser and Patrol brochures a figure is stated but is not on any Prado document to my knowledge.
When I come to needing just a touring wagon I may well buy a Prado but knowing its weaknesses I will do what I can to make it better just as I do with my Patrols only real weakness (fuel consumption).
FollowupID: 570207
Follow Up By: Crackles - Friday, May 16, 2008 at 22:53
Robin, Marty has a 2006 Prado which is a 120 series. It has the same width axles as an 80 series and being no taller would not have the stability issues you mention. Correct me if I'm wrong but aren't you speaking of the earlier & narrower 90 series in relation to the RACV test? Totally irrelevant in this discussion.
Cheers Craig.............
FollowupID: 570316
Follow Up By: Robin Miller - Sunday, May 18, 2008 at 18:51
Hi Craig
No , I was specifically reffering to later models , and in my reply above I refer to the early ones and state that later ones are a little better.
To this end the GXL Prado's increased there track width from 1505/1510 to 1575/1575 with the new model hence getter a little better. (there more than just track width to this equation)
The 80 series track widths were 1595/1600 in the same GXL variant.
You have to be a little careful with this stuff as you can get significant variations between models particularly when production runs of a basic chassis can occur over several years.
FollowupID: 570586
Reply By: Wizard1 - Friday, May 16, 2008 at 09:55
I'm with John, why are you even botherig to post the question on the forum. Seems as though your reluctant to give up the Prado for a variety of reasons.
What I think is even more bizarre is why people need to put such questions of individual choice on a forum to start with.
I have had a Prado TD for over 6 years and intend to keep it for a few more. It is extremelly reliable, never had any serious mechanical problems and comfortable. I certainly don't need the feedback of others to help me decide what I will replace it with whe the time comes.
The only limitation is the 2500kg tow capacity as I want a larger caravan.
The Prado still is one of the best mid size 4WD on the market.
AnswerID: 304099
Follow Up By: Big Marty - Friday, May 16, 2008 at 10:45
Wizard,
Fair coments, but having not been around australia before I was wondering if I was missing something in regard to the use of a petrol vehicle for the journey as there seems to be so many diesel fans out there.
I've decided that I'll use the prado for the trip, but if there are any prado people out there, what assesories should I fit, such as bull bar, winch ?, under bosy protection etc ?
Big Marty
FollowupID: 570169
Follow Up By: ben_gv3 - Friday, May 16, 2008 at 11:08
Geez Wizard1, give Big Marty a break.
Just because some of us aren't as experienced as you shouldn't mean we can't ask simple questions, I know I've asked a few.
Talk about making someone feel welcome, you must be the life of the party if someone has a differing opinion to you.
FollowupID: 570175
Follow Up By: Member - John and Val W (ACT) - Friday, May 16, 2008 at 13:26
Big Marty,
I rather agree with John. If we are to give you a useful answer you first have to give us a bit more info to go on. And you also have to work out what YOU want to do in terms of where you want to go, for how long, with what degree of comfort etc. When you have answered those type of questions then you will have a fair idea of what you really need (as opposed to want). Also have you had a really good look at all the info on this site, or do you just think its easier to ask a minimal question to supply answers for you?
It takes time to set up a rig, and it tends to evolve as you get experience. Start by doing some short trips, as others have suggested.
Petrol is not an issue. We, in our old but very reliable and thirsty Troopy are about to set off on a 17000 km trip, going into some fairly remote areas. The point is to plan carefully, and trip planning is IMHO half the fun of a trip. You are the only one who can do that.
Having said that, OziExplorer is very worthwhile as it allows very detailed trip and route planning to be done very easily.
Val.
J and V
- Albert Einstein
FollowupID: 570205
Follow Up By: Big Marty - Friday, May 16, 2008 at 13:54
Val,
Okay, just wanted to start with the right vehicle, then I'll set it up.
FollowupID: 570209
Follow Up By: JTPrado - Friday, May 16, 2008 at 15:10
Big Marty,
Have a look at the Pradopoint forum at http://www.pradopoint.com
You will find many enthusiastic Prado owners who are very helpful
FollowupID: 570219
Reply By: Member - MUZBRY (VIC) - Friday, May 16, 2008 at 10:06
Gday Marty
I went around the block , in a 1952 Holden, so i cant see why a Prado can't go.
Murray
AnswerID: 304101
Follow Up By: Member - MUZBRY (VIC) - Friday, May 16, 2008 at 10:07
Also, my mate went around in a 1948 Austin A40 panel van.
Those were the days.
Murray
FollowupID: 570163
Follow Up By: Member - David P (VIC) - Friday, May 16, 2008 at 10:58
My father towed a caravan over Mt Hotham behind an Essex during the 1939 bush fires!!! Your trek will be a doddle IMHO....:))....cheers...silverback
FollowupID: 570172
Reply By: Big Marty - Friday, May 16, 2008 at 10:46
Sounds like you're from the days men were made of steel and ships of wood ! LOL
AnswerID: 304106
Follow Up By: Member - MUZBRY (VIC) - Friday, May 16, 2008 at 12:05
Marty
What i was getting at is, use what you have and be happy.All we had in 1965 was a bloody old Holden ,and we drove every river and bull dust road we could.
I now drive a 1992 Patrol and would leave tomorrow if i could get away.
Murray
FollowupID: 570187
Reply By: Mal58 - Friday, May 16, 2008 at 11:54
Big Marty,
A 2006 Prado will have no problems. I have a 98 V6 Prado.
In 2000 I did 11.5K kms to QLD, Fraser Island, mid north QLD to Kurumba, Mt. Isa etc.
In 2001 I did 5.5K kms around Flinders Ranges etc,
In 2004 I did 3.5K kms around Tassie,
In 2005 I did 5.0K kms around Broken Hill, White Cliffs etc,
All of these trips pulling a Tent Camper and loaded up with the fridge and all the gear that 3 kids and my spouse deem fit to take.
Never missed a beat, not even a flat tyre. Each trip, I averaged approx 15L/100km fuel consumption.
The Prado, is a much underestimated mid sized 4wd that many will bag as not being capable etc because it is not a large 4wd.
Go and enjoy what you have, it will be fine.
Mal
AnswerID: 304119
Follow Up By: Big Marty - Friday, May 16, 2008 at 12:15
Hey Mal,
Your just the person I need to talk to, I intend to take the v6 Prado around Oz towing a a tent camper and 3 kids in the boot.
Big Marty
FollowupID: 570189
Follow Up By: Mal58 - Friday, May 16, 2008 at 16:36
Hi Marty,
If you want to discuss off-line, email me with your questions at
MalcolmdotCdotLewis@Telstradotcom
Just replace the "dot" with a .
Mal
FollowupID: 570241
Reply By: Member - Richard K (NSW) - Friday, May 16, 2008 at 11:54
My 2002 Prado is the best thing I've ever bought, I would take it around/through Australia today if I could get a leave pass. Sure, a LC or Patrol etc might have more ultimate ability, but I reckon a Prado will get to 95-98% of places any other standard 4wd will go. Being lighter than a full size rig also has advantages eg many people rave about Prados for sand driving.. I can't wait to get mine out into the Simpson...
Gotta love the fuel range and the general niceness of how they drive.
There ya go!
Rich
AnswerID: 304120
Reply By: Member - Olcoolone (S.A) - Friday, May 16, 2008 at 12:57
Big Marty, why don't you think a 2006 V6 Prado is capable of touring around Australia?
Regards Richard
AnswerID: 304130
Follow Up By: Big Marty - Friday, May 16, 2008 at 13:06
Richard,
Well when i raised the question of Diesel over Petrol I got hammered by the oil burners saying that I should join the Oil burner fraternity. They made me feel like I was sub human owning a V6.
Well bugger them I say, I'm going to do it in a V6 and report back to the clan here on my progress !
Big Marty
FollowupID: 570204
Follow Up By: Member - Olcoolone (S.A) - Friday, May 16, 2008 at 13:27
Mmmmm, Your Prado will do it very very easily.
Ignore the petrol/diesel debate...sure you will use more petrol, but more then likely the economy of the diesel will be out weighed by the cheaper cost of petrol and the cheaper cost of the V6 Prado over diesel.
Get good tyres.
Maybe look at putting a suspension kit in (for weight and clearance).
Have the vehicle checked and serviced.
Get a UHF.
Use a Next G phone with car kit and external antenna.
Maybe a sat phone (buy/hire).
Fit a steel bull bar.
Fit a set of good driving lights.
Get a GPS (not a $249.00 special).
Fit a cargo barrier.
Fit a fire extinguisher (one in the cargo area and one in the front).
Get a good first aid kit (with stuff like tablets for most sicknesses).
Do a advanced first aid course.
Carry recovery gear and fit recovery points.
Carry 20 to 40 lts of water.
Get a good car fridge (Waeco or Engle)
Fit a auxiliary battery.
And take with you music on CD in MP3 format, only enough food for 2 days more then the longest time to the next town, road maps, 3 good torches.
Regards Richard
FollowupID: 570206
Follow Up By: poppyg2 - Friday, May 16, 2008 at 16:07
I have a 02 Prado petrol and have towed a camper trailer through Kimberley's, NT, SA & outback WA and found it to be generally reliable ,except for a few bits of plastic that fell off, electric Window winder packed up & window supports shook loose & the squeeks & rattles that wont go away. My biggest problem is the fuel economy which has been fairly poor. PoppyG
FollowupID: 570233
Follow Up By: bill320 - Friday, May 16, 2008 at 20:48
Mate, I have a 2002 V6 Prado.
I would do the loop in what you have got. Lets just say that I think that my driving ability doesn't extend beyond my cars capabilities. If your question relates to fuel consuptions I cant help you. However, unless you are a experienced 4wder, I would think that the either car would work well until the driver points it in the wrong direction.
FollowupID: 570299
Reply By: Big Marty - Saturday, May 17, 2008 at 09:42
With reference to the soft underbelly, I'm fitting a ARB sump guard.
I've received quotes for a snorkel, they want to charge $630 for a ARB one fitted, does this sound right ?
Also what type of bull bar should I fit, there are so many on the market, I don't really like the look of the Toyota one, the ARB ones seem to cost $2500 fitted.
I also intend to fit a roof cage, rino seem to make a good one, does anyone have any suggestions there ?
Big Marty
AnswerID: 304294
Reply By: krausz - Wednesday, May 28, 2008 at 16:25
Whats wrong with prado? I have a 98 prado and just done the trip in february from WA Port hedland to cairns on the savannah way, through wet, dry, flood, rocks and what else was there fully loaded up, before i was actively going to bush for days on end and newer ever one hickup with car. may be the sharp rocks chew of the tyres more or less but the car was excellent. So just prepare the best you can for safety etc. enjoy your trip u will be fine.
AnswerID: 306330
Follow Up By: Big Marty - Wednesday, May 28, 2008 at 16:34
Yeah well, I've come to realise that I have a pretty good vehicle. I intend to get a sump guard fitted, snorkle, bull bar, roof cage and cb fitted. Will be towing a 18 Ft Caravan.
Big Marty
FollowupID: 572323
Follow Up By: krausz - Wednesday, May 28, 2008 at 17:26
Oh no one mentioned to you yet, get an EPIRB ! Roof cage? well you have your caravan to load up.
krausz
FollowupID: 572328
Reply By: krausz - Wednesday, May 28, 2008 at 17:10
Big Marty u have an email address?
AnswerID: 306337
