2nd battery question
Submitted: Sunday, May 18, 2008 at 19:45
ThreadID: 57735 Views:2690 Replies:2 FollowUps:2
Looking at putting a 2nd deep cylce battery for added capacity in camper trailer and looking for advice if what I want to do will work OK.
What I want to achieve is to be able to run the camper off one battery while the other one is charging. When the first is charged flick a switch and changeover running camper to fully charged one while the first one is being charged.
Currently running 123W solar panel with 3 stage charger / regulator.
The way I had in mind to wire it up would be:
1. Output from regulator into VSR.
2. Input from car into VSR same terminal as regulator.
Switchgear I'm looking is here.
Will it work or is there a better way of doing it?
Reply By: nikademus - Sunday, May 18, 2008 at 20:08
Wouldn't you be better off hooking the two batteries up in parallel if you are after more capacity? It would save switching...
AnswerID: 304559
Follow Up By: Mogul - Sunday, May 18, 2008 at 20:11
Too many issues with charging them both properly.
FollowupID: 570618
Follow Up By: Nomadic Navara - Monday, May 19, 2008 at 00:39
Not really - you are opting for the hard way. For interconnecting batteries see -Site Link
FollowupID: 570682
Reply By: Affordable Batteries & Radiators - Sunday, May 18, 2008 at 20:10
Hi Mogul
The solar panel can't keep the VSR engaged so it won't work.
Also from my own testing you are better off having one battery bank. Don't try running 2 banks as this is hard work and rather leave the solar regulator to do the thinking for you.
Derek.
AnswerID: 304562
