GU brake shake
Submitted: Tuesday, May 20, 2008 at 17:01
Member - Vince M (NSW)
finally got sick of the front wheel shake after heavy long braking changed the rotors for slotted & holed & it is great, I always thought the rotors were distorting when hot. set the old ones up spun them & heated them up & they distort terribly & when they cool down back it shape.
hope this helps others
regards Vince
Reply By: Michael ( Moss Vale NSW) - Tuesday, May 20, 2008 at 18:58
Where did you buy them from Vince?? Michael
304916
Follow Up By: Member - Vince M (NSW) - Wednesday, May 21, 2008 at 20:46
Auto pro & Brake pro
571160
Reply By: autosparky - Tuesday, May 20, 2008 at 20:12
watch for pad wear
304940
Reply By: Ozboc - Wednesday, May 21, 2008 at 17:53
drive an auto do we???
Never had brake overheat even when fully loaded up with my Jayco ( 1250 lkg + all
camping gear )
but then again the trailer does have electronic brakes!
Boc
305108
Follow Up By: Member - Vince M (NSW) - Wednesday, May 21, 2008 at 20:59
No a 4.2 TD manual patrol six wheeler that is often at its GMV of 4500kg & towing the same.(& it is legal) Its the second one I've had & over 600,000klms in the first & 200,000klms in this one the old 94 never had the problem & if you look back thru the
forum there's been plenty of GU with this problem
regards
Vince
571161
Follow Up By: Ozboc - Wednesday, May 21, 2008 at 23:07
Ok, then in that case .... maybe a suggestion -- i had seen on the Truck races that the big rigs actually have a
water spray / jet set up that spray
water direct onto the disks - This obviously helps to cool them - would not to be hard to rig up with a simple 12 v pump you can buy from any auto one or similar and a
water resevoir
as the disks are hot - they
water should not effect breaking as it will evaporate quickly ......
a cheap easy option to think about ????
Boc
571198
