Jerry Can Question
Submitted: Wednesday, May 21, 2008 at 20:50
jdwynn (Adelaide)
Howdy forumites
Bought some new yellow diesel plastic jerry cans today.
Never used plastic before. Are they good to go, or do you need to wash then out with diesel first?
Cheers JD
Reply By: Member - Oldplodder (QLD) - Wednesday, May 21, 2008 at 20:53
Had no problems using
mine straight offthe shelf.
Looked pretty clean inside , did check for foriegn objects.
305158
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, May 21, 2008 at 21:30
You mean like a beautiful female genie?? Michael
571166
Follow Up By: Member - Oldplodder (QLD) - Thursday, May 22, 2008 at 07:48
Didn't think of checking for those, just lumps of plastic left over from the mold..
She may have drowned, will look more closely next time :o)
571213
Reply By: Member - Vince M (NSW) - Thursday, May 22, 2008 at 07:59
Used
mine straight away & never had a problem, they have done some trips too, canning, the cape, simpson to name a few I use a large plastic strong crate that fits 3 perfectly with a bit of marine carpet on base & sides. By the way i have found that the blue
water ones to be the best for not leaving that PVC taste
regards Vince
Ps the ones i have are slinghtly wider at the base & are the Scepter Brand made in Canada (They make a lot of fuel tanks for the marine industry)
305209
