New Coleman Dual Fuel Lamp "Surge"?
Submitted: Friday, May 23, 2008 at 13:32
ThreadID: 57915 Views:3269 Replies:4 FollowUps:3
I have just purchased a new Coleman Lantern, it has two mantles, and is slight smaller than the NorthStar.
I have assembled the unit strictly according to the insructions and now that it's alight, it "surges". It sort of alternates between a whitish glow to a more yellow colour, perhaps every one or two seconds. When the yellow flame is present, the flames extend out the top of the unit. I'm using Coleman Fuel.
I cam also hear dripping or gurgling of liquid when the lamp is turned on. Is all this normal? Is there a break-in period where everything settles down? Too much pressure? (I did the 30 strokes just liek the instructions).
Anty advice greatly appreciated.
Reply By: Member - Brett M (QLD) - Friday, May 23, 2008 at 14:21
Hi ,
This normally occurs when there is not enough pressure in the tank. I normally pump 30 strokes into the lantern and then light it.
After it is lit I turn it to about half on the adjustment and then add roughly another 100 strokes. This will most likely solve your issue.
Brett.
AnswerID: 305457
Follow Up By: RalfR - Friday, May 23, 2008 at 14:46
Thanks Brett, worked a treat!!
A bit brighter too.
Cheers for that.
FollowupID: 571470
Reply By: RalfR - Friday, May 23, 2008 at 21:00
At least it improved the situation a fair bit, however now that it's running better the light intensity continues to fluctate quite a bit, once again every 1-2 seconds, it dims for a little bit and then goes back to normal. It's quite disconcerting with the light fluctuating so much. Am I expecting too much, or is this one of the "charms" of liquid fuel lanterns?
Is this functioning normally, or is there something else I should do?
Thanking you all in advance.
AnswerID: 305521
Follow Up By: Mike Harding - Friday, May 23, 2008 at 21:14
It sounds as if the lamp is faulty - I suggest you return it, Coleman are very good in this regard.
Mike Harding
FollowupID: 571558
Reply By: The Rambler( W.A.) - Friday, May 23, 2008 at 23:58
TRy turning the brightness control knob quickly off and fully on --do this about 5-10 times while the lantern is lit. It is a self cleaning action on the jets and may fix your problem.
AnswerID: 305545
AnswerID: 305546
Follow Up By: Member - Graham H (QLD) - Saturday, May 24, 2008 at 08:35
Dont know about the new ones but we used the old Tilley lamps for about 5 years.
The usual reason for flaring was either dirty fuel or blocked jets or in our case quite often both.
FollowupID: 571599
