Winching
Submitted: Saturday, May 24, 2008 at 15:26
Name Not Found
How do you set up for reverse winching. ie. winch backwards not forwards, if situation ahead is deteriorating, not just one 'bog hole'. e.g beach, unforseen swamp area, black soil
Reply By: Member - Davoe (Yalgoo) - Saturday, May 24, 2008 at 15:33
Like this??????????
Winch
305608
Reply By: KiwiAngler - Saturday, May 24, 2008 at 16:17
Reply By: Member - John F (NSW) - Saturday, May 24, 2008 at 17:01
I agree with Davoe and all the ?????? re the link he posted. As some others observed on that
forum, all that setup will do is tear your vehicle in half.
There are others here much wiser than I, but I would assume you could use a hand winch attached to the rear ( I believe there are some who advise that it is a more useful and versatile device than the expensive, heavy and
water intolerant devices many insist on bolting to the front of their vehicles).
Of course some people may get a lot of use from their electric
winches but some are never used - but that is off the topic.
Do any
winches have a roller attached to allow the cable to pass under the vehicle?
Regards, John.
305624
Reply By: TrevorDavid- Saturday, May 24, 2008 at 18:54
Tirfor...........and some grunt
305644
Reply By: Member - Royce- Saturday, May 24, 2008 at 19:59
I'm sure there's a winch somewhere that you can fit to your towbar instead of the square tow tongue...
Found this...
http://www.wipo.int/pctdb/en/wo.jsp?WO=1993017886&IA=WO1993017886&DISPLAY=CLAIMS
Ah.. here it is
http://www.watling-towbars.co.uk/4x4_winches.html
305653
Follow Up By: a convict - Saturday, May 24, 2008 at 21:19
Thanks for asking the question, always wondered myself how it is done.
"Watling" winch looks like very, very, handy toy. Many thanks for the link Member - Royce.
571719
Follow Up By: navaraman - Saturday, May 24, 2008 at 22:47
A winch mounted on a towball sounds a bit dodgy to me.
571729
Follow Up By: Member - Royce- Sunday, May 25, 2008 at 00:45
They're not attached to the ball, but fit into the towbar as the tow tongue does.
If that's dodgy,... then towing is too..
571742
Follow Up By: navaraman - Sunday, May 25, 2008 at 02:31
from the website,
"The Helpmate winch is then lowered onto the towball and secured with the locking pin." you can see it in pic 3
571744
Follow Up By: Member - Royce- Sunday, May 25, 2008 at 11:31
Ah yes.. you are right.. lowered onto towball.
Anyway... so is a trailer.. I guess that would be better, because it would allow articulation.
571809
Reply By: garrycol - Saturday, May 24, 2008 at 20:01
I my landie FC101 - I just run the cable out through the rear and winch away - the advantage of having a mid mounted PTO winch on the side of the chassis that works forward or back:)
305654
Follow Up By: disco driver - Saturday, May 24, 2008 at 23:11
Hi garrycol,
Shows the advantage of having a real 4x4 rather than those unmentionable pretend ones.
Shame about the V8's fuel consumption though.
I once had a Landy109 fitted with a front PTO capstan winch, would outperform any electric one available at the time. A couple of suitably designed pulley blocks in the right
places and you could pull from any direction, including backward.
Disco.
571734
Follow Up By: navaraman - Saturday, May 24, 2008 at 23:36
"A couple of suitably designed pulley blocks in the right
places and you could pull from any direction, including backward.'
Aye, they'd be real handy on a Landy.
Patrolman Pat
571741
Reply By: samsgoneagain - Sunday, May 25, 2008 at 19:10
look up the warn pullzall. cordless winch
305801
Reply By: Robin Miller - Sunday, May 25, 2008 at 21:24
I have a patrol , with synthetic rope , and the angles of thr winch mount I made allow the rope to be just thrown under the car and it
winches backwards as on the Patrol the rope underneath only touches the two axles.
The above reduces the winch pulling power to about 1/2 but this is still a lot more than a hand winch and a hell of a lot easier.
305841
