duel relay 08 hilux
Submitted: Tuesday, May 27, 2008 at 12:27
warbo
how do i wire my spotties with a duel relay with terminals s1,s2, batt on one side and L1,L2, earth on the other. with a toggle switch which lights up when on. (driving me mad!)
Reply By: Member - Chris & Debbie (QLD) - Tuesday, May 27, 2008 at 18:50
warbo,
Are you running two sets of spots or one? If 2 sets you are better running 2 toggle switches one for each set, toggle 1 going to s1 then L1 to one set of spots. Toggle 2 to S2 with L2 going to the second set. You could use one toggle to operate both sets at once (or one spot from each relay) by just using a jumper lead across S1 & S2, of cause the wire to the toggle switch will come from your high beam then to S1/S2
Chris
306155
Reply By: warbo - Tuesday, May 27, 2008 at 19:41
chris i am running 1 set of lights 1relay /light (L1 to one light L2 to the other) bridging s1to s2 on switch but positive earth on hilux has got me stuffed just need to know how to tap in.
306166
Follow Up By: autosparky - Tuesday, May 27, 2008 at 20:33
throw that spot relay away use a simple 5 terminal bosch type (far simpler to wire up . but you can use the other type as
well
take wire from the centre terminal to toggle switch
fromthe other side of toggle switch to s1
earth s2 (i think) if i remember correctly
572177
Reply By: autosparky - Tuesday, May 27, 2008 at 20:35
should be centre terminal of headlight connector
306181
Follow Up By: warbo - Tuesday, May 27, 2008 at 20:54
autosparky can you tell me from start to finish? bits and pieces from here and there don't compute!
572182
Reply By: autosparky - Tuesday, May 27, 2008 at 22:24
email your phone no to waconsofraptors@iinet.net.au and i will talk you thru it
306216
Reply By: Member - Olcoolone (S.A) - Wednesday, May 28, 2008 at 17:37
Red with yellow trace is the switched negative supply on the left and right hand light that turns on high beam.
Black is positive on the right hand light and red is positive on the left hand light, both the black and red wires have power all the time.
If you were to use a standard mini 4 pin relay you would connect the red with yellow trace to pin 86 and the red or black wire to pin 85 of a relay, pin 30 via a 20 amp fuse to the battery and pin 87 to the positive of
the spot lights.
As Patrick said join S1 and S2 together and connect it to the RED or BLACK wire on the back of the headlight (RED left hand headlight and BLACK right hand headlight).
Connect the S terminal to the RED/YELLOW wire at the back of the headlight.
B to battery via a 20 amp fuse.
S to RED/YELLOW wire at back of head light.
L1 to positive wire on one of
the spot lights.
L2 to positive wire on the other spot light.
S1 & S2 can be joined together and connected to EITHER the RED wire on left hand headlight and BLACK wire on the right hand headlight.
If you want to put a switch in you will have to put it in the wire that goes from terminal S to the RED/YELLOW wire on the back of the head light.
Most of the times when we install spot lights we don't fit a separate switch to turn them on and off...just another thing to go wrong and extra work for something you may not use.
Don't forget to earth each spot light.
Regards Richard
306339
Follow Up By: autosparky - Wednesday, May 28, 2008 at 19:43
it is not legal to wire spotlights without an independant switch to turn them off independantley of high beam
572352
Follow Up By: Member - Olcoolone (S.A) - Wednesday, May 28, 2008 at 22:58
Didn't say it was legal!
572398
Follow Up By: autosparky - Wednesday, May 28, 2008 at 23:14
thats why in wa i have to have a license to be an autosparky and a/c fitter . to cut out the back yard hacks
572401
Follow Up By: Member - Olcoolone (S.A) - Thursday, May 29, 2008 at 10:03
So what are you getting at I'm a back yard hack?
A/C is not just i WA as you think it is Australia wide.
572444
Follow Up By: Member - Olcoolone (S.A) - Thursday, May 29, 2008 at 10:33
Autosparky you don't drive a BT-50 do you.
572447
Follow Up By: autosparky - Thursday, May 29, 2008 at 20:40
no there is no suggestion that you are a hack however the right advice should be given . licensing of all tradesmen here in wa that work on vehicles . and maintaining miame
572544
Follow Up By: autosparky - Thursday, May 29, 2008 at 20:41
no dont drive bt 50 whats that
572545
Reply By: warbo - Wednesday, May 28, 2008 at 20:59
Autosparky, Thankyou for your help as I just hit the computer I also read Richards thread, went out to my ute. Where I went wrong was I had S going to earth instead of through my switch via red yellow wire. Thankyou all for your help. Nice rig Richard. What beach were you on? Looks good. So how do I close this thread??
306380
Follow Up By: Member - Olcoolone (S.A) - Wednesday, May 28, 2008 at 23:05
The photo was taken half way between
Goolwa and the
Murray Mouth.
You don't need to close the thread...it will stay here for ever (or until David cleans out his server) and end up like every other wed site.
572399
