Rear storage drawers
Submitted: Friday, May 30, 2008 at 19:07
ZukscooterX90
Good evening fellow EO people.how do you anchor your rear drawers in the back when the fuel
tank is underneath it? Best to answer this Q is those that have made there own.
Thanks Bob.
Reply By: Dave(NSW) - Friday, May 30, 2008 at 19:16
Hi Zukscooter,
Most people use existing bolt holes either for baby seats or from rear seats being removed, Hope this helps.
Cheers Dave...
306810
Follow Up By: ZukscooterX90 - Friday, May 30, 2008 at 19:35
Thanks Dave i should have mentioned the said 4by is a suzuki estate wagon 94 mod. no back row seats the box sits behind the rear seats which will be laid down or removed to make more room if needed as i will be travelling on my own.
Bob.
572699
Follow Up By: Dave(NSW) - Friday, May 30, 2008 at 23:27
Bob,
If it is anything like the siera fit some captive nuts in the wheel arches & use some braces from there.
Dave...
572745
Follow Up By: ZukscooterX90 - Saturday, May 31, 2008 at 19:13
Thanks again Dave,got under the rear late thi afternoon & found room to drill a hole either side of the said drawers into the floor just behind fuel
tank.
Bob.:)
572861
Reply By: Brew69(SA) - Friday, May 30, 2008 at 19:16
I made my own Bob and was able to use the seatbelt
anchorage points for the third row of seats. Maybe there is an existing point of some sort you could look for and attach some sort of bracket.
306811
Follow Up By: ZukscooterX90 - Friday, May 30, 2008 at 19:36
Thanks Brew see my reply above with Dave.
Bob.
572700
Reply By: stefan P (Penrith NSW) - Friday, May 30, 2008 at 20:36
I used the holes for the baby seats
306819
Reply By: Trevor R (QLD) - Friday, May 30, 2008 at 21:14
Hi Bob,
I used the four luggage tie down points in the cargo area of the GU. If you have them in the Suzy, take them out and use bolts and threads from them to secure drawers.
Alternatively, is there a cargo barrier available for that car? and if so the securing brackets for the cargo barier may be able to be bought and used for the drawers?????
Cheers buddy,
Trevor.
306831
Follow Up By: ZukscooterX90 - Saturday, May 31, 2008 at 19:16
Hey Trev, thanks for your reply.I think i have it sorted now (read above follow up.
Bob.:)
572864
Reply By: Hairy (NT) - Friday, May 30, 2008 at 23:35
Gday,
Im not really sure on what you're doing ....but...do you know about uni-strut?
http://www.unistrut.com.au/
306864
