Wiring of driving lights to prado
Submitted: Saturday, May 31, 2008 at 15:35
ThreadID: 58224 Views:4925 Replies:2 FollowUps:0
Hi all, I'm having issues with wiring of these lights and getting them to work. The lights are lightforce, the wiring loom is one of those ones already made up from TJM which they use on all there lights, heavy duty. Now I have wired plenty of them up before and never had any issues so what the f#@%. The relay sits in one of those holders with the wires coming up into the base you just push the relay into it (hope you know what I mean). I have no 86 being direct power from the battery with an inline fuse and fuse is ok, 25 amp, 87 running out to lights, 85 goes to switch on dash then back out again and picks up the power from the high beam wire from behind headlight, I'm presumig no 30 goes to earth ?? Or have I got this all a rse about ?? Bit hard to see exactly where all the wires are going as they are running throught that ribbed plastic stuff and all taped up. Regards Steve M
Reply By: nickb - Saturday, May 31, 2008 at 15:46
30 - fused to battery
87 - spotlights
85 - switch
86 - ground
hope that helps
AnswerID: 306961
Reply By: Stephen M (NSW) - Saturday, May 31, 2008 at 16:18
Problem fixed, faulty new relay. Thanks anyway. Regards Steve M
AnswerID: 306967
