LPG/Diesel findings
Submitted: Monday, Jun 02, 2008 at 20:08
Steve
ok, it's just over 4 weeks since I had my LPG fumigation done by EcoShot. Their claims of about 30% more grunt and 20% better economy I was a bit sceptical about. Two days after the "operation" I went 800ks up to Straddie towing around 1500kgs, with car loaded to gunwhales with the usual
camping gear, wife, kids and dog. The car is a Defender 300tdi, which are a bit underpowered but excellent on fuel economy (10L/100ks) not towing and 13L/100ks @ 95ks towing.
I reckon I did about 10% better on economy and regarding the performance.....
well, I can
well believe the 30% claim. Furthermore, having returned to my normal routine, without having any specific dyno stats (which I'll have done later in the year) I know I must have at least the claimed 30% improvement in power. I get up familiar hills in higher gears without any effort. Absolutely delighted in this regard. Must admit though, I'm a bit disappointed in the fuel/economy aspect. I reckon there's a 10% improvement, no more. Having said that, once you factor in that some of the usage is LPG (65c per liter) in dollar terms the economy is about 17% improvement. The other thing is the extra range you get due to the extra 30L
tank. The diesel
tank is 79L and the lpg one is 30L but you only use 20L per
tank of Diesel - so, effectively 99L of available fuel which will get me around 950/1000 ks, not towing.
The cost was $3600 less $2000 (thankyou Johnny) and further tax relief made it
well worthwhile for me. The power was the main motivation. Crawling up those long hills at 60kph whilst towing and kidding on I don't care that every other bugger was zipping by like I was standing still is now a distant memory. I can get up there at the giddying speeds of 80 kph or more. Much better in soft sand too.
The settings are adjustable and I am still in the process of finding the right balance. I'll be taking it to Graeme Cooper for a tickling up and we'll see what the dyno readings are.
I said I'll report back, so I hope somebody finds that of some use.
Reply By: Dunaruna - Monday, Jun 02, 2008 at 20:39
Quote - "Crawling up those long hills at 60kph whilst towing and kidding on I don't care that every other bugger was zipping by like I was standing still is now a distant memory. I can get up there at the giddying speeds of 80 kph or more."
I have a theory.
The availability of increased power is directly proportionate to wanting to use that power. In other word, it's there so you will use it.
If you were to continue to travel up that
hill at 60kph, your right foot would not be pushing on the pedal nearly as hard as before the conversion. Therefore, you would see much better economy.
It would be interesting to test that theory but most conversion owners are to busy enjoying the extra power.
307378
Follow Up By: Steve - Monday, Jun 02, 2008 at 21:28
got it principally for the power and it uses 10% less fuel
read the post
573242
Follow Up By: Dunaruna - Monday, Jun 02, 2008 at 22:02
Huh?
573257
Reply By: Saharaman (aka Geepeem) - Tuesday, Jun 03, 2008 at 07:40
HI Steve,
Thanks for the follow up experience - its always good to get first hand experience with the end result. I have researched these systems for a while but have decided to wait until I upgrade my 4x4 first rather than convert an old vehicle.
I also like Ecoshot from what I have read but would be interested in what made you choose that one over some of the other systems such as - diesel/gas; Ecomix; D-Gas; GFSI etc etc.
There is so much evidence around that gas injection has positive results but I am still trying to determine which system works the best. I have read recently that some of the big trucking companies are now trialing gas injection as
well but they are using the GFSI system I unnderstand. Maybe there is not much of a difference in the different ones - they all do basically the same thing I guess. But any comments you have on Ecoshot also the customer service aspect would be appreciated.
Enjoy the new power!
Glen
307451
