Best way of keeping spinifex from under the vehicle
Submitted: Tuesday, Jun 03, 2008 at 07:13
chris_s
I have heard (but not seen) people attempting to keep spinifex from under their vehicle. One method I've heard about is to put shade cloth stretched across chassis. How effective are such methods?
I'm planning to do the CSR next month.
Chris
Reply By: Member - Chris R (NSW) - Tuesday, Jun 03, 2008 at 08:03
First reaction is that this might slow air flow and increase potential for fire. Doubt it would stop spinifex and would probably make difficulty in
clearing it - as I guess it would need
clearing for the stuff it stopped.
With regards travelling long distance with this - suspect it would couse great inconvenience as various obstacles and road conditions would soon be wanting to rip it.
Several layers across bullbar are recommended in some posts. I know from personal experience that flyscreen across the front is is completely ineffective
Found that occasional underbody check is easy and makes for a break. As CSR will be
well travelled, most spinifex will be short. If you go into the long stuff, then check ftrquently and discover where it collects
Chris
307454
Reply By: Willem - Tuesday, Jun 03, 2008 at 08:16
Chris
See post 58311 for my replies.
Shadecloth under the chassis will most likely be torn off if veturing off track or if you scrape the chassis over a
sand dune. The CSR should be relatively free of spinifex or grass seeds as other veheilces wqould have cleared the track by now.
I once saw a mining vehicle on the Kidson Track and it had a chain mesh screen attached to the chassis behind the engine to stop foliage from collecting in the chassis.
My thought now is to have bigger
wheels and maybe a body lift.....but that all seems too hard for the occasional foray into the Never Never...lol
307456
Reply By: traveller2 - Tuesday, Jun 03, 2008 at 08:22
We always have flyscreen across the radiator, directly over any trans/aircon/coolers in front of it.
When in grass country we wrap the whole front of the vehicle outside the bullbar and back to the front
wheels in shadecloth.
As has been said you will not stop it.
I recently removed the radiator after our Madigan crossing last year and it was approximately 10 -15 % blocked by seed heads despite the above.
This was after a/c condensor and oil/trans cooler!
As regards underneath good advice given in earlier post, check often. In really bad conditions remove the bash plates so that it can't accumulate under the truck.
Also keep an eye on rear brake backing plates and
wheels as late model vehicles with traction control seem to catch fire at the rear maybe due to brakes being very hot?
Spinifex in bad conditions will catch fire with the friction from rotating items like tail and halfshafts just rubbing on them.
If it is later in the season and on track you should have little problem as previous vehicles will have lopped it all off.
307458
Follow Up By: Willem - Tuesday, Jun 03, 2008 at 08:51
Yep I have backing plates on rear wheel removed as
I think that this was the cause of a burnt out Nissan on the
Gary Hwy or
Hunt Oil Road some years ago.
573318
Reply By: Member - Doug T (FNQ) - Tuesday, Jun 03, 2008 at 08:36
Chris
Have one of these in front might fix the situation.
Image Could Not Be Found
307463
Follow Up By: Willem - Tuesday, Jun 03, 2008 at 08:49
Hahahahahaha!!!!!
573317
Follow Up By: Member - Footloose - Tuesday, Jun 03, 2008 at 10:46
Ditto :)
573331
Follow Up By: Pajman Pete (SA) - Wednesday, Jun 04, 2008 at 17:37
And 4WD to boot!
573567
Reply By: MEMBER - Darian (SA) - Tuesday, Jun 03, 2008 at 10:23
How about that fine SS mesh for termites ? Don't know how wide it is - used on building sites. Anyway, it is a big issue - was talking to a bloke only a few days back on my VKS737 sked - he was in the WA deserts and was just 'mopping up' after a spinifex fire under his vehicle - had to do a bit of temporary wiring to restore systems and was able to proceed - phew - so easy to lose the lot !
307481
Reply By: Member - David P (VIC) - Tuesday, Jun 03, 2008 at 13:11
Hi Chris,
I was wondering if a 'curtain ' of chain link, like those plastic cutain strips the fish@chip shops use, located just behind the front cross member.....cheers
307508
Reply By: Member - Roger B (VIC) - Tuesday, Jun 03, 2008 at 21:42
It wasMarch 2002, and we were in
Coffin Bay SA, about to head into the NP, when a couple of members of the Pt. Lincoln constabulary arrived on the scene, on their way to try and bust some naughty people allegedly growing a 'crop' deep in the
park. They stopped to pull a veh out of the sand, and told us that they were not very popular with their Sgt., and higher police at that time, as earlier in the day while on some mission, they had parked their shiny, almost new Land Cruiser in some long grass on the side of a track, and were conducting some investigations nearby, when lo and behold their cruiser caught fire!! Apparently the hot exhaust had ignited the grass, and the rest is history!! Burnt it completely out. This story was confirmed in the local paper the next day.Cheers.
Roger B....
307612
Reply By: Stephen M (NSW) - Wednesday, Jun 04, 2008 at 14:04
Have been told on petrol models to remove the cat convertor as this is the main cause of fires on petrol vehicles due to the extreme heat they produce around and including the cat itself. Totally ilegal I would imagine but dont think anyone is going to worry out there. Bloke we do tag alongs with wont let petrol vehicles tag along unless it's removed. Also would be worth carrying one of those 10 litre pump up poison sprayers from bunnings and keep full of
water just incase, fire extingher will last you 30 seconds if your lucky, at least with a sprayer you can get the wand right into the area you need to. BUT hopefully you wont need to use it but better to be sure. Regards Steve M
307716
Reply By: chris_s - Wednesday, Jun 04, 2008 at 16:33
Thanks everyone for your replies. Looks like there is no easy way to do it except crawl under with a wire hook and take the crunge out. The 10L pressure bottle sounds worthwhile,
Chris
307732
Reply By: Vivid Adventures - Wednesday, Jun 04, 2008 at 17:27
I'm just back from the CSR.
Most of the track is already trimmed by the vehicles going before.
Exceptions are:
Calvert Range track - we would appear to be about the second vehicle out there this year, but from what I understand there are many more with permits; and some of the less travelled side tracks (Helena Springs etc), or the Western "optional" track that skips
Well 44, for instance, and even then, the spinifex is not that bad this year.
307747
Reply By: blown4by - Saturday, Jun 07, 2008 at 22:47
There is no easy way. A couple 4mm rod hooks with handles, some washing up detergent bottles filled with
water and some elbow length boilermakers leather gloves and check often if you want to avoid a fire. Re the shade cloth in front of the radiator be aware it does restrict air flow and need to be easily removable for regular cleaning
308441
