Triton '98 diesel 'coughing'
Submitted: Tuesday, Jun 03, 2008 at 07:52
ThreadID: 58321 Views:2655 Replies:5 FollowUps:1
Hi each
My '98 Triton 2.8 Diesel with after market turbo (otherwise going like a rocket) is coughing and spluttering for a few seconds after starting in the morning from cold before settling down to it's usual perfect purrrrrrrrrr.
Shall I shove some Wynns in it???????
Any helpful, knowledgable comments would be appreciated.
Happy days
George
Reply By: Member - Doug T (FNQ) - Tuesday, Jun 03, 2008 at 08:17
Try this
Image Could Not Be Found
Although..............
FORGET expensive cough medicines, when it comes to helping a Triton fight off a cough, the centuries-old remedy of honey is still the best, Mitsubishi researchers say.
They found that a dose in the tank before a drive easily outperformed costly over-the-counter cough suppressants.
Honey was better at cutting the severity, frequency and disturbance from night-time coughs of those Tritons with upper air intake infection.
It also helped their sleep, suggesting that owners may be wasting their money on expensive alternatives sold in Supercheap and Roadhouses.
AnswerID: 307457
Follow Up By: AdlelaideGeorge - Tuesday, Jun 03, 2008 at 08:22
Doug & Dusty
Brilliant! I'll try that!.......but...how many tablets???
I think I'll swallow the honey...
Happy days
George
FollowupID: 573310
Reply By: Member - Doug T (FNQ) - Tuesday, Jun 03, 2008 at 08:28
George
My serious answer.
My 94 Troopy does same sometimes, if it has glow plug warmers give it about 8 seconds before hitting the starter , also check that the filter hasn't got a minute leak , and yes add a bottle of Wynnes diesel Spitfire occasionally, .../ don't rev the motor until it gets the soothing effects from the tablets...lol
AnswerID: 307459
Reply By: Member - Oldplodder (QLD) - Tuesday, Jun 03, 2008 at 08:32
Yep, my 96 2.8 pajero did it too for a while.
Classic symptoms of the fuel pump seals going.
If it starts fine, the glow plugs are OK, then after a few seconds runs rough for a minute or so, possibly pump seals.
Took about 6 months (15,000k) to really develope on mine.
Got to the stage that it just about cut out after starting OK.
If it runs fine when running after a warm up, most probably it, since injectors are OK.
Otherwise, air is getting into the system some where else at rest.
Only needs to be a little bit of air.
The pump seals wear, and when the engine is not running, air gets into the system.
Check and see if you have a small fuel leak at the fuel pump, that will confirm it.
Depends how long you want to keep the car. Cheap(er) option is to just do the seals. Otherwise a full pump overhaul might be the go.
Looking at $600 to $1400.
You need to get it checked by a diesel specialist or a good mechanic who knows their diesels.
What is your fuel filter like?
Found dirty fuel clogs the filters and some gets through to the pump, increasing wear. Happened to me at 240,000k. I know run a pre filter for the fuel.
Overdoing the diesel additive doesn't help either.
AnswerID: 307461
Reply By: howesy - Tuesday, Jun 03, 2008 at 10:24
Its 99% of the time a lazy glow plug and its usually the one closest to where the wire goes on to the bar that goes first. This is a classic sign. They are real easy to check. just loosen the nuts on top and slide the bar out so they are all now not interconnected. get a multi meter and put it on the 200ohm setting and cross the 2 prongs on the meter you will see the reading go to 0.00 indicating no resistance. glow plugs may have some resistance but get one prong on the threaded top and the other scratch hard into the side of the glow plug to give good contact and note the reading on each one. The one that has a much higher reading than the others is the dud one. you can either replace this one or buy a whole new set. they generally range from $18 to $30 give or take depending on the vehicle.
AnswerID: 307482
Reply By: AdlelaideGeorge - Tuesday, Jun 03, 2008 at 11:13
Thanks for all the replies - I'll check closer over the weekend and go from there
R
George
AnswerID: 307493
