Air bags in the rear coils...
Submitted: Sunday, Jul 06, 2003 at 21:44
Brian
OK... my GQ Patrol has those pump up air bags in the rear coils.. one
has a leak where it has obviously been rubbed through by the coil.
Does anyone know if this can be repaired?? Or do I need to bin 'em
and buy newies??? Any opinions welcomed!!! Thanks!
Reply By: diamond (bendigo) - Sunday, Jul 06, 2003 at 21:59
gday brian.
you can just buy one air bag.
fitted one only for a customer a few weeks back.new job coming so no fraser this time:-((
24363
Follow Up By: Member - Cocka - Sunday, Jul 06, 2003 at 22:11
In one has rubbed through wouldn't you bet that the other one was probably close to the same. If it had been puctured that would be a different matter, you'd just replace the one.Carpe Diem
16382
Follow Up By: diamond (bendigo) - Sunday, Jul 06, 2003 at 22:25
gday cocka.
we checked the other side good as gold.
was the one near the exhaust and was 5 yrs old.
new ones a little heavier.new job coming so no fraser this time:-((
16385
Reply By: mrdesmo - Monday, Jul 07, 2003 at 01:17
A quick question....I got airbags in my new(ish) 80 series, one side is flat, there are air valves mounted on the towbar underneath so I am assuming they run to the airbags. (Could be the shocks, I doubt it, but I haven't had time to have a decent look)
What pressure do you run the bags at?
How much to replace a popped one?
24372
Follow Up By: ramp - Monday, Jul 07, 2003 at 10:18
minimum is 5 psi maximum is 30 psi,i think there about $300 per set but that includes hosing,valves and top rubber
seat. give heasmanns (02)9557-5930 a ring.
16392
Reply By: Bob Y. - Qld - Monday, Jul 07, 2003 at 17:41
Brian,
Have had Polyairs in an 80 series for over 18 months, and while I wouldn't rave over them, they do keep the rear up when loaded. Was cheesed off when one developed a leak, turned out to be the hose not the bag. So I would check the hoses before you buy a replacement bag.
Hooroo...
24409
