Using a UHF radio
Submitted: Saturday, Jun 07, 2008 at 11:59
Member - Wendy C (NSW)
We have just had a
UHF radio installed in our Landcruiser and have not used it yet. Does anyone have any advice? What channel is used by caravanners? We will be travelling with a small off-road caravan from
Sydney to
Darwin next month and then touring around
Kakadu, Arnhem Land,
Alice Springs and
Yulara.
Reply By: Member - Alan H (QLD) - Saturday, Jun 07, 2008 at 12:13
Caravans use channel 18
Motorhomes use channel 20
General road channel is 40
Outback tracks sometime use 10
308324
Follow Up By: Gramps (NSW) - Saturday, Jun 07, 2008 at 14:37
LOL is there some sort of class system between caravans and motorhomes ?
574182
Reply By: Member - Phillip S (WA) - Saturday, Jun 07, 2008 at 13:09
Mostly use 40 on the road....language can be a bit blue.....but you usually pick up road maintenace crews ahead who want to be heard by road train operators....rarely 18....but sometimes I use the scanning feature and you pick up allsorts,.....station people etc, it will latch onto the stongest signal if any...hope this helps.
308330
Reply By: Crackles - Saturday, Jun 07, 2008 at 13:10
Additionally the truckies use 40 whom you may need to speak to occasionally to let them know your intentions when passing etc. Channels 1 to 8 are repeater channels as are 31 to 38 & not normally for general chat. (Check your manual on how duplex works) It is a courtesy once you've made contact on the main channels to swap over to a free one if you intend to waffle on ;-)
Cheers Craig..............
308331
Reply By: Member - Nev (TAS) - Saturday, Jun 07, 2008 at 13:54
Reply By: Motherhen - Saturday, Jun 07, 2008 at 14:16
We stick on 40 and have UHF 40 on back and front of caravan.
If you see us on the road, say hello
308338
Reply By: Member - Bob & Lorraine S (NSW - Saturday, Jun 07, 2008 at 14:27
Hi Wendy
What model radio do you have? Some will allow you to scan all channels and you can set your priority channel as 18 ( for example) for transmitting to another caravan. A quick press of a button will take you off scan and you can turn the dial to change to a different channel to transmit (40 or 29 for example if you want to speak to a truckie)
Lorraine(&Bob)
Clipper811
On the Road
308342
Reply By: Richard Kovac - Saturday, Jun 07, 2008 at 14:49
Wendy Hi
Hope this works, I'm not saying it's right but helpfull.
Image Could Not Be Found
Richard
308346
Reply By: Richard Kovac - Saturday, Jun 07, 2008 at 16:01
Wendy
There is also a copy in members file swap
PDF
or
link
308358
Reply By: MEMBER - Darian (SA) - Saturday, Jun 07, 2008 at 16:17
Which radio (make - model number etc) have you bought ?
308364
Reply By: Member - Wendy C (NSW) - Saturday, Jun 07, 2008 at 17:03
Thanks everyone. The model is GME TX3440.
308375
Reply By: Member - Bob & Lorraine S (NSW - Saturday, Jun 07, 2008 at 17:41
Wendy
That model allows you to scan and have priority channel. Setup as group scan (GS). The manual is easy to follow-I did it-lol
Lorraine
308381
Reply By: Louie the fly - Saturday, Jun 07, 2008 at 17:55
Another thing is to familiarise yourself with the jargon and the phonetic alphabet. We have an emergency plan on a laminated card. It just has some basic "speak" on it as an example for the radio to follow if they are inexperienced. This is kept in the car and our kids know how to use it. If you get injured your kids may be the ones who have to save your life.
Your UHF can also be a good source of fun (your can hear some pretty funny stuff at times) while on the road, as
well as a means of meeting fellow travellers. Have a good trip, lucky ba*&%rds!
308384
