POWER PLUG CAR TO CARAVAN
Submitted: Tuesday, Jun 17, 2008 at 10:00
ThreadID: 58882 Views:2850 Replies:5 FollowUps:4
Gidday all,
We have just purchased a newish caravan and on it there is a different power plug on it (Car to Van plug). Instead of having the 7 pin plug that I am used to, it has a rectangular plug with two rows of pins, about 7 on each row. (one row of pins bigger than the other)
Does anyone have these and if so what are the advantages over the 7 pin. Is it worth keeping it and changing the car adapter or changing the plug on the van
Thanks in advance.
Reply By: Gronk - Tuesday, Jun 17, 2008 at 10:20
12 pin flat is what you have........no big advantage if you don't need any more wires than you already have....I used to have one on my old CT and the extra big pins were good for charging the CT batteries...
Check 1st, but they may have the fridge wires on the big pins ( won't matter if the car isn't set up to run the fridge ) or the onboard battery ( has it got one ? )
AnswerID: 310476
Follow Up By: Member - Mark G (NSW) - Tuesday, Jun 17, 2008 at 13:09
why cant they just make 1x tow ball size & 1x trailer plug ( oh god, common sense raises its ugly head again)sorry,he he :-)
FollowupID: 576524
Reply By: Member - Big Al. Gold Coast - Tuesday, Jun 17, 2008 at 13:33
Mick
We have the same on our van, the large pin's are for (the 5 Pins )
battery charging
Direct line to van fridge
Earth return
Auxiliaries
Rear fog lamps.
I have combined the fridge and van battery line on the vehicle as they are supplied by the 2nd aux. battery in the vehicle.
AnswerID: 310510
Follow Up By: mick - Tuesday, Jun 17, 2008 at 14:47
Hey Big Al,
Thanks for the reply, what are the small plugs for and how do you power the electic brakes? Any advantage having this type of plug?
Mick
FollowupID: 576536
Follow Up By: Member - Big Al. Gold Coast - Tuesday, Jun 17, 2008 at 18:49
The large pins take a heaver guage wire.
The service brakes (blue wire) go to pin 5 on a 12 pin flat trailer socket
FollowupID: 576591
Reply By: Member - Vince B (NSW) - Tuesday, Jun 17, 2008 at 15:19
I have a 12 pin plug & use pins 8 to 12 for the camper trailer.I originally had a 7 pin plug but had trouble on the Plenty Highway when the trailer brakes & constant power wires decided to mate.
The smaller pins ,1 to 7 are used for blinkers, earth, stop lights & clearance lights.
Cheers.
Vince
AnswerID: 310532
Reply By: austastar - Tuesday, Jun 17, 2008 at 15:22
Hi, have a look at
http://www.campertrailers.org/trailer_wiring_diagram.htm
AnswerID: 310535
Reply By: lancie49 - Wednesday, Jun 18, 2008 at 08:30
This may be an obviously stoopud kweschun, but a 12 pin plug will fit a 7 pin socket won't it ?
Lance
AnswerID: 310710
Follow Up By: Dunaruna - Wednesday, Jun 18, 2008 at 09:16
No, but a 7 pin plug will fit into a 12 pin socket.
FollowupID: 576697
