Nissan Vibrations
Submitted: Thursday, Jul 10, 2003 at 15:16
ThreadID: 5904 Views:2036 Replies:4 FollowUps:3
I have a 3.0L TD patrol - it is almost one year old, and has done 28,000 kms, it has started to vibrate from 100 kph.
I have been back to Nissan several times. I have had wheel balances done to no avail. They have also removed some of the shims which has not helped at all.
I am still complaining to Nissan as the car is under warrantly, but seem to be getting nowhere fast with it.
Does anybody have any ideas which could help me out? It is becoming extremely frustrating.
Bec
Reply By: bruce.h (WA) - Thursday, Jul 10, 2003 at 15:44
Bec
welcome to nissan driving ,have alook at post 5883 & 5798
as they will have what you are looking for
regards Bruce
AnswerID: 24601
Follow Up By: Bec - Friday, Jul 11, 2003 at 11:27
Thanks Bruce I appreciate your help.
FollowupID: 16604
Reply By: Eric - Thursday, Jul 10, 2003 at 23:23
Bec.
It may be a bit rude to ask but have you checked if the wheels are round. To test just jack up the axle close to a wheel until the tyre clears the concrete by 1mm then rotate the wheel and check if the gap remains at 1mm. Eric.
AnswerID: 24651
Follow Up By: Bec - Friday, Jul 11, 2003 at 11:28
Thanks, I appreciate your help. I have been told this by a mechanic yesterday, it is something I will definately look at.
FollowupID: 16605
Reply By: Steve from Drive Systems Victoria - Friday, Jul 11, 2003 at 11:22
A common but frustrating fault that has plaqued Nissan's for some 20 odd years. Some do it, others don't. It is related to tyre/wheel balance and out of round and usually raises it's ugly head when tyres are changed or rotated.At least, that is the common denominator. Tyres need to be stripped off the rims and inspected internally for bubbles,delamination, balance, out of roundness. Same with the rims, they need to be balanced without a tyre and again with a tyre and even then, rotation of the tyre on the rim several times to get the "high/heavy" spots to counteract each other. It's a long,expensive process that Nissan dealers will not have the time for. You need to find a freindly tyre store that is prepared to spend several hours searching for you, and even then, you have to be prepared to scrap tyres and replace them, even though they look good.
Welcome to motoring, Nissan style. If you have access to another set of rims and tyres, give them a try and at least this will confirm that it is a wheel related problem that has gone on far too long with this vehicle.
AnswerID: 24682
Follow Up By: Bec - Friday, Jul 11, 2003 at 11:29
Yes I've been told this a few times in the last day or so, something I will definately look at. Does this mean if it is a tyre problem, that I may have to be changing tyres every 30,000 odd kms?? Thanks for your help.
FollowupID: 16606
Reply By: Patrol22 - Friday, Jul 11, 2003 at 16:13
Bec
I had a similar problem when I changed from the original HTs to BFG ATs. Nothing seemed to help despite 3 or 4 balancing efforts by the company that fitted the tyres. A friend suggested a Bob Jane T-mart gold balance might do the trick - and it did. Now have 50K on the tyres and the problem hasn't raised its ugly head again. From memory the gold balance is about $25 per wheel but well worth it.
Pete
AnswerID: 24702
