Redarc Wiring
Submitted: Saturday, Jun 21, 2008 at 11:19
ThreadID: 59056 Views:6447 Replies:3 FollowUps:5
Hi all am in the market to buy a Redarc dual battery isolator, just need to know how they are wired up as three people have told me 3 different ways. I wanna do it all myself as i will save some money for fuel fro my Gibb trip. What i can gather from online is that there are only 2 cables that are fed to the Isolator, 1 from the starting battery and 1 from auxilary. Also does the negative from the auxilary earth to the car or engine block or do i feed connect this back to the starting battery negative? Do i need to fuse both positive cables coming from isolator with a 100amp maxi fuse or anl fuse? Batteries are mounted end to end and cables wont be more then 60cm long. Vehicle is Landcruiser 75 Diesel and its the 100amp redarc isolator.
Thanks in advance for any help.
Reply By: Member - Craig M (QLD) - Saturday, Jun 21, 2008 at 11:52
If indoubt..........ask the manufacturer
Here's the link
link
Check out the PDF drop downs
Craig
AnswerID: 311425
Reply By: Affordable Batteries & Radiators - Saturday, Jun 21, 2008 at 16:35
If you plan on using the jump start feature you can't use fuses.
The instructions in the box are quite good and you can download a copy from redarc.com.au
It is a simple VSR and DIY is the way to go.
Derek.
AnswerID: 311457
Follow Up By: Member - Graham H (QLD) - Saturday, Jun 21, 2008 at 17:14
And be nice and buy one from Derek .His prices are quite good
FollowupID: 577440
Follow Up By: tukka - Saturday, Jun 21, 2008 at 17:24
Absolutely right, will definitely be buying off Derek.
So Derek all i would need is some 3B&S cable with some lugs and battery terminals and the isolator will be all set to go, plus with the free push button thats included what wiring do i need to get that hooked up. Do i need the 3 B&S or way smaller cable?
Auto electronics really does my head in. I get the idea of it all just like to be really sure that i am doing it right the first time.
FollowupID: 577443
Follow Up By: Affordable Batteries & Radiators - Saturday, Jun 21, 2008 at 17:44
Hi Tukka
3 B&S made up cables ready to go is best.
VSR type isolators are very easy to wire up.
Derek
FollowupID: 577448
Follow Up By: tukka - Saturday, Jun 21, 2008 at 18:37
Excellent yeah i have spotted them, just need to know what i will need for the push button wiring? Will be purchasing soon as i know what i need.
FollowupID: 577457
Follow Up By: Member - Graham H (QLD) - Saturday, Jun 21, 2008 at 18:43
2 bits of wire the same thickness as is on the redarc. buy it all together
FollowupID: 577460
Reply By: Brian - Sunday, Jun 22, 2008 at 04:13
I have a Redarc in my Patrol, it's a quite reliable unit in comparison to what I had prior. Very simple install, just follow the advice above and download the instructions from the internet.
AnswerID: 311554
