Offroad trailer drawbar length?
Submitted: Sunday, Jun 22, 2008 at 16:41
Crackles
Of those that tow trailers into the more remote & rough areas, what maximum length draw-bar (ball to trailer axle) do you see as being suitable to negotiate tight tracks, sharp creeks & High Country humps without side swiping trees on corners & bottoming out excessively?
Just working up a layout for a custom built off-road trailer & other than allowing a minimum 1.2m from the tow hitch to the front of the box to be able to jack knife, what measurements do owners have on theirs & does it compromise articulation in the rough stuff.
Cheers Craig...........
HZJ105 Vic.
Reply By: Member - Redbakk (WA) - Sunday, Jun 22, 2008 at 17:00
This is an interesting question.....when you look at some of the dearer offroad campers the distance from the hitch to the axle is long to say the least and certainly not balanced it seems.
I have been going to measure a few at the 4x4 show and enquire about the legal aspect and load/ balance issues however it does not seem to effect towing performance.
Just don't try to pick it up...lol
But they pack a bit on them.
311636
Follow Up By: Crackles - Sunday, Jun 22, 2008 at 18:15
Yes I missed an opportunity to measure 7 campers on a trip of
mine to the Flinders a while back but the longer draw-bars with the big storage box's on the front certainly were at a disadvantage on the sharp
creek crossings & ruts along the Copper track &
Artimore PAR slowing the overall speed of the convoy by at least a 1/3.
577608
Reply By: Member - Nev (TAS) - Sunday, Jun 22, 2008 at 17:25
Hi Crackles,
ADR 43/30 covers it I think.
http://www.comlaw.gov.au/ComLaw/Legislation/LegislativeInstrument1.nsf/0/043FB838C0BD224FCA2571640013091C/$file/ADR+43-04+%5BFINAL+FRLI%5D.doc
I find the longer the drawbar the easier generally to back as it doesn't react as quick.
Rgds
311641
Follow Up By: Crackles - Sunday, Jun 22, 2008 at 18:06
"For all other trailers the ‘Drawbar Length’ must not exceed 5 metres" All I could find Nev was the maximum length & at 5 metres it should be real easy to back ;-)
Cheers Craig............
577606
Follow Up By: Member - Nev (TAS) - Sunday, Jun 22, 2008 at 18:27
Hi Craig,
might be OK for you but oldies like me would almost need to have a spotter from that distance...... lol
rgds
577612
Follow Up By: Member - JohnR (Vic)&Kath - Monday, Jun 23, 2008 at 08:36
I reveresed
mine several hundred metres along a track in East Gippsland when I found a VERY
big tree across the track after fires. 425mm extension helps a lot for reversing. Just using mirrors too Craig
577699
Reply By: Notso - Sunday, Jun 22, 2008 at 17:32
There is also another consideration. The length of the drawbar affects how the trailer tracks behind your vehicle. in other words how it follows your vehicle wheel tracks.
Don't know how it's calculated butthere must be a formula somewhere.
Below is an extract from this site
http://www.expeditionswest.com/equipment/adventure_equip/Jumping_jack.html
For the trailer to track inside the path of the tow vehicle, the coupler to axle hub distance should not exceed the tow vehicle wheelbase. The only real trail restrictions would be as a result of its size (mostly related to the 91" width).
311643
Reply By: jdwynn (Adelaide) - Sunday, Jun 22, 2008 at 17:35
Gem of a subject. However, I reckon the questions you should be asking are 'ramp-over' angle and 'rear departure' angle i.e. account for clearance / underbody features also. Applicable to trailers as
well to 4wd's. Ultimate campers are only manufacturer (to my knowledge) that state these. Some drawbars are so long and it would have to affect ramp-over as
well as hitch load a great deal. One subtle factor in ramp over is hitch mounting height - we've mounted ours as high as we can without stopping rear doors fom opening (got about 10mm clearance!!). Obviously wheel / tyre size can have a large affect as
well. Cheers JD
311644
Follow Up By: Crackles - Sunday, Jun 22, 2008 at 18:47
Yes JD I thought ramp over angle would be the better indicator of off-road clearance too but difficult for the average Joe to measure on their own trailers. The other issue on the length of draw-bar is when turning sharp on narrow tracks the trailer cuts the corner to some degree hitting trees. Interested to see at what point it becomes a problem.
Will match the trailer tyres with 285's, fit coils & mount the tow hitch as high as possible.
Cheers Craig...............
577616
Reply By: a convict - Sunday, Jun 22, 2008 at 17:45
..good topic, I just happened to look up 'www.Alibaba.com'
http://www.alibaba.com/product-gs/206238847/OFF_ROAD_trailer.html
..dead scary pricing, the whole trailer kit, tent, etc., $US 1100-1300, min order 25 units. Check the details.
311647
Follow Up By: Vivid Adventures - Sunday, Jun 22, 2008 at 18:24
Now you know where 1iberty campers are made.
577611
Follow Up By: Crackles - Sunday, Jun 22, 2008 at 18:58
I think they've used the words "Offroad" pretty loosely with that model :-)
Must be some factory though , 30 trailers can roll off the assembly line each day!
577619
Follow Up By: Vivid Adventures - Sunday, Jun 22, 2008 at 21:26
30 a day ... chuckle. No. If you place an order for 30 per day, they will be happy to arrange to supply it - either by moving to a newer bigger factory, or working with their mates.
577663
Reply By: MEMBER - Darian (SA) - Sunday, Jun 22, 2008 at 19:38
Just ran the tape measure over my 04 Campomatic Hard floor (flip over) camper (ind coil,
suspension). The actual box is 2300mm long (not including the rear swing away spare wheel). The road wheel centreline is 1100mm from the BACK of the box. The drawbar reaches to 2050mm from the front of the box (tip of the hitch). This trailer has a wedge shaped storage box on the drawbar, to accommodate tight turns. Been good for us to date - has seen plenty of twisty turning bush travel and
creek beds etc.
With the 120L
water tank full (underside - right at the back) the 'ball-weight" is about 90kg.
311676
Follow Up By: Member - Redbakk (WA) - Sunday, Jun 22, 2008 at 21:51
Darian....what is the distance from the hitch to the centre of the
wheels ( axle line) and from the centre of the
wheels to the rear of the trailer.....thanks m8
577673
Follow Up By: MEMBER - Darian (SA) - Monday, Jun 23, 2008 at 10:42
Hitch to centre of axle line; 2300 - 1100 = 1200 + 2050 = 3250mm.
Axle to rear of trailer = 1100mm.
577722
Follow Up By: MEMBER - Darian (SA) - Monday, Jun 23, 2008 at 10:46
Forgot to include - old pages on my site [
http://users.picknowl.com.au/~darian/JackCampo ] ..... some camper photos there may be of use - all other info there out of date.
577724
Reply By: Member - Oldplodder (QLD) - Sunday, Jun 22, 2008 at 19:46
I tow a few trailers.
No 1 has a short drawbar of 1200mm.
Tows OK but a b*gger to reverse.
No 2 - My box trailer is 1500 long and not bad. Good compromise.
The CT is a 2m draw bar and tracks
well, but can still jack knife it.
For clearance over humps the CT is as good as the others, if not best as it has a higher hitch.
All have 15" or 16"
wheels for clearance.
Go the 2m, more space on the draw bar to mount stuff, like spare wheel and tool box.
311681
Reply By: Member - JohnR (Vic)&Kath - Sunday, Jun 22, 2008 at 23:22
Craig, a few of the
Kimberley Karavan owners are fitting drawbars extended but over 400mm from standard. We reckon we get better control and better balance on the towbar. Of course it can lesten the weight applied to the back of the car. Will measure it up tomorrow. It has been up in the HC to no particular disadvantage.
311719
Follow Up By: jdwynn (Adelaide) - Monday, Jun 23, 2008 at 07:46
John, the Karavan hitch - axle distance doesnt look as great as the longer K/Kampers. Any idea how it compares? Cheers JD
577692
Follow Up By: Member - JohnR (Vic)&Kath - Monday, Jun 23, 2008 at 08:30
JD, it is the same chassis in actuality but quite a few have a heavy duty square section in where the original Treg fitting fitted and extended it forward 425mm. The corner of the back of our ute brusied the multibox the very first time we refueled on the road while turning with a 300mm extension. Kath can jack knife to a far greater extent without hitting anything.
I have fitted a bike carrier in there on the drawbar for our last trip but that can hinder swinging the wheel on a rear wheel carrier on a turn to the left.
I had to extend the connections to the Karavan battery charging and lighting/braking lead too fitting the extended bar. Too easy.
577697
Reply By: Brian (Montrose, Vic.) - Sunday, Jun 22, 2008 at 23:51
Has anyone looked at a fairly short drawbar setup, within reason, still with room for a box or what ever on it. But, to make backing easier make the A frame with an extendable middle beam that can be pulled out to give greater manoverability when reversing or for more stability at speed?
Just a thought I had awhile ago after folding my little rubbish trailer under the back of the ute... :(
311722
Follow Up By: Member - JohnR (Vic)&Kath - Monday, Jun 23, 2008 at 08:32
Brian, you could do that but you would need check chains too, to make sure nothing got lose. My drawbar extension is firmly bolted and Locktite'd in place
577698
Follow Up By: Crackles - Monday, Jun 23, 2008 at 17:20
Have seen a couple on boat trailers with 1m extenstions to avoid backing the car into salt
water but for offroad use flexing of the draw bar may be an issue.
577800
Follow Up By: Michael ( Moss Vale NSW) - Monday, Jun 23, 2008 at 18:46
Brian, Check my post below,. Michael
577822
Reply By: Member -Signman - Monday, Jun 23, 2008 at 08:41
Just measured
mine..(trailer that is)...
From axle to pin of Treg hitch = 2700mm
From front of 'box' to pin of hitch=1590mm
From axle to rear of box=900mm
311735
Follow Up By: Crackles - Monday, Jun 23, 2008 at 21:12
Signman going on measurements I've seen so far yours are pretty much on average with the axle just behind the centre of the box ensuring a little draw-bar weight. How have you found it for reversing & tracking behind the car?
577868
Follow Up By: Member -Signman - Tuesday, Jun 24, 2008 at 08:28
No probs reversing.. I have a 80 metre long (narrow) driveway. Once I get things straightened up, the trailer tracks very nicely.
Any other info. you need, let me know...
577918
Reply By: Michael ( Moss Vale NSW) - Monday, Jun 23, 2008 at 18:44
Gday Craig,
I asked a similar question a few months ago. I have a H/D offroad box trailer, the box is 6' x 6' with internal guard with the draw bar being 1000 mm from the front of the box. I find that with the short drawbar,the trailer waddles behind, especially on dirt roads at speed. Also getting to the
barn doors on the Patrol is difficult. I have decided to make a telescoping single bar and have it adjustable at 1200mm and 2200 metres. I have all the metal tubes and bit fabricated and i was hoping to have it complete before
Innamincka next month but i have just ran out of time to put it together. So the short, although a little longer than in have now will be good for tight tracks and i can stretch it out for the highway.. I hope i can complete by Xmas.. Michael
311838
Follow Up By: Member - JohnR (Vic)&Kath - Monday, Jun 23, 2008 at 19:01
Michael, that is huge. Never imagined a 22 metre draw bar let alone a 2200 metre one. You would hardly see the
barn doors from the trailer.
577830
Follow Up By: Michael ( Moss Vale NSW) - Monday, Jun 23, 2008 at 19:10
Hi John, I measured a mates C/T and it was a 6x4' box trailer and it was 3.2 metres from treg hole to axle. OHH! LOL, just re read you post.. Yep Typo!!! 2.2metres., actually i think it was actually 2.1 metres.. I am going to leave the A frame and just section the current metal, weld it in and pin it for the telescoping positions.
Michael
577831
Follow Up By: Crackles - Monday, Jun 23, 2008 at 20:53
Micheal it appears that your trailer being under 3 m in total is actually shorter than just the draw bar on some others campers :-) You're confirming my thoughts that the off-road clearance, particually the ramp over angle will need to be compromised to some degree in order to get it to track straight & make reversing easier.
577860
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Jun 24, 2008 at 09:47
Craig,
I wont have the associated problems with a long drawbar as i will be able to shorten the telescoping drawbar down to as low as 1200mm from the treg pin hole to the front of the box, thats only about 200mm longer than i have now,, Michael
577932
Follow Up By: Brian (Montrose, Vic.) - Tuesday, Jun 24, 2008 at 20:10
Micheal,
So what you've got is an extendable A frame that is pivoted so that when it is lengthened it still forms the A correctly or is it just a pull out centre beam as I was thinking about earlier?
Brian.
578012
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Jun 24, 2008 at 22:47
Hi Brian, I havent actually fitted it all yet. I have it all fabricated and ready to weld in. A 100mm SHS with a 4mm wall tube is the outer and an 89mm SHS with 5 mm wall is the inner, i plan to leave the current very strong "A" frame, just section the 100mm out of the middle and weld the outer tube in. it will have 2 positions, 1200mm from the front of the box and 2100mm, adjustable by two 20mm pins.
Michael
578058
Reply By: Robin Miller - Monday, Jun 23, 2008 at 21:32
My new home built one appears to be working out fine Craig.
Its essentially a 2.4m by 1900mm wide flat box with a 1300mm from tow ball to front of box.
This makes it 2500mm from tow ball to axle but this increases by 50mm as
suspension takes up under load.
This allows it to carry 3 bikes with bolt on channels , and these can be removed and other top deck arrangements used in future.
Finished weight was $300kg of which 104kg is in the 3 235/85/16
Patrol
wheels.
Just looking at it you would think the axle is to far back but it balances very
well with 15kg down thrust unloaded onto the front jockey wheel.
We thought about it a lot and ended up putting the spare wheel underneath and just behind the axle.
We have throughly checked its clearances in use and it seems to be fine, we can almost put trailer at right angles to the car.
Handles bumps
well after fitting some new shock bump stops.
The trailer coupling can be attached to the car in 4 different ways by mounting above and below the cars tongue.
311901
